tire sensors
Old Dec 15, 2019 | 10:44 AM
joebyrnes's Avatar
joebyrnes
Default tire sensors
how much will the dealer charge to re-set the software code to remove check system light if everything is good with the tires and sensors
Old Dec 15, 2019 | 11:40 AM
See5's Avatar
See5
Hi,
Check system light mostly means faulty sensor/s which needs replacement, not just programming. The light can't be turned off.
I suggest using Tech stream to determine how many sensors are faulty and program new ones yourself.
For the dealer of course the charge will differ from case to case but will be higher.
Old Dec 15, 2019 | 12:57 PM
Zmon's Avatar
Zmon
Originally Posted by See5
Hi,
+1.
If the light is on, you have a faulty sensor and it will need to be replaced. There's really no way for you to check which one is bad yourself unless you have access to Techstream. Just about any tire place can do this for you though, and replacing the sensor shouldn't be more than $20-30 on top of the cost for the sensor. A Denso sensor can be had from Amazon for $40, give or take.
Old Dec 17, 2019 | 01:52 PM
timmy0tool's Avatar
timmy0tool
you can go to your local America's tire and they can diagnose the sensor (and even clear the light) for free!
yes likely one of the batteries in a sensor is low, but at least they will be able to tell you which one by the scanner they use.
the scanner as the ability to scan the health of each sensor and program them back into the TPMS ecu.
Old Dec 18, 2019 | 07:20 AM
sinister2c's Avatar
sinister2c
You probably need new sensors if they are over 7 years. A whole set of OEM Denso/Pacific brand are $135 on ebay. I've been on mine for 1.5 years.
Https://ebay.to/2M8Kdhh
On Amazon for $35 each prime. https://amzn.to/2PBty8m
foureye
RX - 4th Gen (2016-2022)
Oct 10, 2019 01:01 AM
lovecd
Dec 11, 2018 07:34 AM
7Train
May 17, 2018 06:51 PM
Marexus
Jan 12, 2012 06:15 AM
