Hi I really need help with this issue. All the lights on instrument panel are lit. It wasn’t as bad earlier today (only check vsc, check engine and traction control
were on) and on the way back driving on highway the break(parking break light) light flashed and then went away. Then when I get home and restart the car all the light start to light up, engine temperature is showing cold but in fact it was just on highway. And the power steering gave away as well.
similar thing happened a month ago when it was raining hard. The power windows stop working, keyless entry didn’t work, wiper only worked on high speed, turn signal didn’t work. But after driving around it all worked again until now.
It felt like it’s a electrical issue. Any one has any suggestion on what to look for? I took to a shop OBD says ecu has issue and they don’t want to touch it.
I am at NorCal and any suggestion to where to take the car.
thank you in advance.
