WInter time block heater
Old Dec 7, 2019 | 05:07 PM
Zynthe's Avatar
Zynthe
Default WInter time block heater
I was looking around and I cant find a definitive answer if the IS250 can have a block heater installed. I see a part (PU14000902) but it seems it's for a IS350 and ISF. Other places i've looked show I can only install a heating pad and not an actual block heater.
I was wondering if it's possible to install a block heater in the IS250 and if so would the part PU14000902 from Lexus work? Is there an OEM option for the IS250?
Old Dec 7, 2019 | 05:37 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
PU140-00902 is no longer available. The latest part number for the IS250/350 block heater is PK5A4-08J13. You should be able to pick it up from any local Canadian Toyota or Lexus dealer without much issue.
Jeff.
Old Dec 8, 2019 | 06:40 AM
StanleyR's Avatar
StanleyR
It's impressive that you don't have to drain any coolant/remove any frost plugs to install this!
Another well designed option from Toyota/Lexus!
Old Dec 8, 2019 | 06:45 AM
Zynthe's Avatar
Zynthe
Jeff.
Thanks for the info!!! I was trying to look up the new part number you provided online but there's no info on it. Are you sure Toyota/Lexus will have the part number in their system?
Old Dec 8, 2019 | 08:15 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Yes, they will have it.
Jeff
marc5383
Jan 16, 2018 05:08 PM
StrLitIS
Jul 13, 2017 12:31 PM
connan23
Mar 28, 2013 01:51 PM
Dew23
Mar 23, 2013 08:28 AM
yoyo
Oct 25, 2005 03:16 PM
