Downstream denso sensor for RWD
I purchased two downstream sensors from rockauto
234-4521 for the right which is RWD
But the left one I just realised it says AWD and part number is 234-4518 but rock auto have no denso for downstream left for RWD. Am I missing something? Why is there not senso Left for RWD. I'm now stuck with the AWD one for the left, wondering if it will work? What's the difference?
Just compared it and the wire for the left one is extremely long compared to the original. It almost seems like the right one I was supposed to get two of as for rwd the right on works for both I think. I'm now stuck with this and need to try and just tie up the excess cable under the car somewhere
this looks real confusing on the number of P/N listed for the same sensor...maybe the longer harness?
But for $60 for a Denso OEM replacement vs. $200+ at dealer, can't beat that.
Its on Amazon with prime for the same price as Rock Auto: https://amzn.to/34s0rYY
Here are the factory part number for the oxygen sensors on the 2IS sedan:
IS250 RWD
Upstream RH (B1S1): 89467-30010 (06-08 up to 02/08), 89467-30040 (08 from 02/08 on-10), 89467-53040 (11-12), 89467-22050 (13)
Upstream LH (B2S1): 89467-30010 (06-08 up to 02/08), 89467-30030 (08 from 02/08 on-10), 89467-53030 (11-12), 89467-22030 (13)
Downstream (B1S2, B2S2): 89465-30730 (Qty: 2)
IS250 AWD
Upstream RH (B1S1): 89467-30020 (06-08 up to 03/08), 89467-30040 (08 from 03/08 on-10), 89467-53040 (11-12), 89467-22050 (13)
Upstream LH (B2S1): 89467-30010 (06-08 up to 02/08), 89467-30030 (08 from 03/08 on-12), 89467-22040 (13)
Downstream RH (B1S2): 89465-30730
Downstream LH (B2S2): 89465-53230
IS350 RWD
Upstream RH (B1S1): 89467-30010 (06-08 up to 02/08), 89467-30040 (08 from 02/08 on-10), 89467-22050 (13)
Upstream LH (B2S1): 89467-30010 (06-08 up to 02/08), 89467-30030 (08 from 02/08 on-10), 89467-22030 (13)
IS350 AWD
Upstream RH (B1S1): 89467-30040 (11-12), 89467-22050 (13)
Upstream LH (B2S1): 89467-30030 (11-12), 89467-22040 (13)
Toyota to Denso Aftermarket Cross-Reference
89467-30010: 234-9051
89467-30020: 234-9058
89467-30030, 89467-53030: 234-9068
89467-30040: 234-9048
89467-53040: 234-9067
89467-22030: 234-9144
89467-22040, 89467-22050: 234-9129
89465-30730: 234-4521
89465-53230: 234-4518
Jeff
IS250 RWD
IS250 AWD
IS350 RWD
IS350 AWD
Jeff
IS250 RWD
IS250 AWD
IS350 RWD
IS350 AWD
Jeff
IS250 RWD
IS250 AWD
IS350 RWD
IS350 AWD
Jeff
