View Full Version : Maintenance
- 95 SC400 AC Charge
- Cracked Winshield =(
- SC400 Shock Replacement
- 90k Service Parts list for 2001 GS300
- Vehicle Platinum Care
- Sales at Advance Auto
- Mobil 1 on sale at Costco
- sc300 oil change
- Bad Es300 engine
- Need some Techs with expertise gs300
- 92 sc400 oil change. need help!!
- repair manual ?
- Tranny Filter change... Worth it?
- Where did my oil go?
- Anyone mailed Lexus corporate?
- engine idle problems
- Dealer estimates on things you can do yourself
- VSC, Brake Light, abs lights - all on
- Vsc Trac Off Cel
- lots of slack on power steering...
- What Oil Should I ??????
- Oil for 2008 RX 350
- brake booster line
- Transmission Flush Concept Revisited
- Royal Purple motor oil REVIEW
- Check Engine Light '97 es300
- Non-Lexus Question
- Dark Tranny fluid after one change...major problem or?
- Valve cover gasket?
- 2000 ES300: Cause of idle and acceleration surging?
- Help vacuum switching valve??
- ES250 Engine Problem
- 90k mile service question
- tool to change cbest settings ourselves?
- Timing Belt: years or miles?
- Master List of CEL Trouble Codes
- all you guys with the lowered cars!
- Please help with this code
- "Oil changes every 3,000 miles: not for everyone"
- buying a high milage lexus???
- o2 sensor
- ? about oil change
- Lifetime Oil Change from Local Lexus Dearlship
- Help me decide which oil
- Timing belt- age vs miles?
- Oil Filter Question
- VSC/ABS OFF indicators in the dash..
- need to replace my fuel line
- PS Pump bearing?
- Engine makes a nasty smell
- Dealer recommened MOC treatment.
- What do you guys think of the Carburetor Cleaner and MAF Cleaner?
- Question about using the fuel additives
- New Exhaust
- ES300 Sun Visor
- What would you do?
- peg clips for engine shroud cover
- 1998 Lexus GS300 door will not lock
- Service by the book
- Just purchased 1994 LS 400 -- Need advice on Maintenance.
- GX470 30K service $940.00!
- My car will not start
- Shifting into PARK at 30MPH
- How can I get rid of the "maintance required" icon after I had the oil and filter cha
- 30K service
- spark plugs on an 04 ls430
- Fluid still dark after a drain and fill?
- Toyota 100K Maintenance
- 92 sc400 tensioner
- Servicing a sc400
- Faint Squeeky Noise... Possible Bearing Failure?
- Trans Fluid change with WS?
- Major Exhaust problem
- I hope somebody can help
- 99 LS400 sway control question
- Copper crush gaskets on powersteering rack
- Bad Odor from GS300
- Oil Filters: The Old High Quality One?
- 75 Tips For Keeping Your Car In Great Shape
- One O2 sensor causing others to go bad?
- tranny fluid question
- Cloudy Headlight Fix for about $1.29
- O2 sensor
- Any difference going to local shop rather than dealer to get 30K??
- Maintenance for 100k
- 92 sc door lock, tilt problem
- ES250 Hot Running Engine
- Cabin Air Filter
- Bad fuse/relay
- need help
- Hard to start when cold
- ES250; Changing control arm bushings.
- SC400 Jumped timing belt?
- Motor Mount Replace '99 LS400
- Help Please, What is a Flexpipe?
- Backlight on instrument cluster
- Ripped Strut Boot
- Hypermileage
- 91' ES250 firing order HELP!
- A Bit Short of Lexus But I'll Take It
- Disassemble Throttle Body to Clean?
- Jersey Shore Mechanic
- Boston Independent Mechanic?
- Leaking powersteering on a SC300
- ISC 350 Fresh Air door broke
- 1st Oil Change - Used 1998 GS400
- 2001 LS430 Transmission Problem
- SC3 trunk won't stay open
- Alternator failing?
- heated seats question
- LS 430 Spark Plug Change
- Coolant/Anti-Freeze type
- GS400 rpms @ 80 mph
- How to replace tranmission solenoids
- Where to get Toyota T-IV Fluid??
- Transmission Fluid Question
- need a paint shop???
- Thicker Oil?
- Traction Control -02 IS300
- How many lbs of freeon needed for R-12?
- SC430 Rear endlinks
- Automatic Tilt Steering Motor I just came up with a great idea...
- new plugs and wires, but what brand???
- A/c has a stink smell in SC400
- Error Code 0420
- Gas Filler door on my IS300 is Sprung
- 2003 GS430 60k Service
- Need Help With The Locks
- Mistsuguy!! Power Steering Pump Replacement
- Side mirrors on Sc400 not working all of a sudden.
- Opinion wanted about control arm replacement
- 120K Service - 1998 GS400
- SC300/400 Antenna Mast - Good Ebay Sellers?
- Owner's Manual
- Free alignment?
- Best service in Baltimore?
- Rough Engin Idle
- es 250 power steering?
- r/134a refrigerant
- 2004 Rx 330 Ready For 30k Service...advice, Tips? =)
- 93 Ls400, 161k, help with codes....51,22
- Buying an 01 LS430, what should i look out for?
- Another Question - I'm a newbie
- CAS Fuse
- ES250 Electrical Problems
- Customized License Plate Frame
- Code reader for 93 sc400?.......................
- Front Pads Installed On '04 RX
- 2nd gen GS braking noise
- How to check code for 04 LS430
- air conditioning problem
- Certified dealer cheated me on a 60k service?
- Can anyone recommend a good independent shop for timing belt install
- Tranny fluid question
- AIR injection pump, emissions
- how to reset idle senser in 93 sc300
- IS TRC hack
- Replacing EGR vacuum modulator
- Beck-Arnley fuel pumps?
- leaking valve cover gasket ...
- SST? for is2 OilChange?
- Are these worth it?!?!?! (these = pulstarplug)
- Passenger AIRBAG light!!!
- Should i use thicker oil since the car is so old?
- When to change Spark Plugs
- Help - Car problems
- Sputter Sputter after SP change and Tranny fluid change
- Need 03 Tire Pressure Monitor Sensors (SC430)
- Coolant Flush
- Help - Water on Floor
- Fuel Filter Question?
- air pressure compressor/pump
- Struts/Shocks
- 92 SC400 A/C Conversion questions
- 2004 Toyota Sienna A/C Problem
- Two hoses #6 near T/B
- new brake pads... do the rotors have to be machined?
- Ramps
- Am i cleaning the K&N filter correctly?
- Water Pump, Timing belt?? IS300
- Lexus Dealer No
- Mobile 1 extended performance vs. Mobile 1 synthetic...
- transmission fluid flush???
- Is Rotor Turning/Resurfacing a Scam?
- 93 LS400 Starter DIY
- Replacing Tranny
- Question about mainance!!!
- power steering fluid in '03 gs300
- I will give $5 to who helps me solve this
- Car Overheated
- LS430 air suspension, need help adjusting height!
- Help with Trottle Body Cleaning for GS300
- Key will not come out. Can't change gears
- i need help or adivce if anyone ever experience it
- rack and pinion socket?
- Alternator longevity
- Exhaust question. 'is it bad?'
- Tdc
- A/C smell
- Rear brakes
- R U A lexus technician?
- Oxyen Sensor
- 2001 LS430, 53k service...am I leaving anything out?
- can i get these lexus memory seats to work in another vehicle?
- Lease Maintenance Obligations
- Fuel Filter Change
- amsoil, redline, royal purple, mobile one
- 1999 ES VSC problems
- SC400 wont stay running
- Aristo 2JZGTE VVTI .. ECU Selection.. HElP !
- Replacement pads/rotors/calipers GS300
- maintenance question
- Fuel Injector Cleaner... Which is the best out there?
- Any one has schematic diagram for 2001 LS430 showing Bank 1 Sensor 2 location?
- Hot weather and oil viscosity
- Changing Brake Pads
- Transmission Flush Dilemma
- Question about replacing O2 sensor
- Best priced 90K service in NYC
- Altezza remote programming?
- help...there's a leak
- O2 sensor resistance in 90 degree weather
- Use a Toyota Dealer instead of a Lexus dealer
- Looking for an honest mechanic, B'ham AL
- air intake in CA
- MAF sensor cleaner by CRC
- Questions on oil and gas
- When should I bring my car in for major service?
- Car won't stay on after it starts, HELP!
- Thinking about a switch
- Unusual to get maint appt within a week?
- Is Royal Purple 5w30 any good?
- bushing replacement
- 2000 RX300 Air Filter
- Engine light on
- When to make first Oil Change for New Engine?
- Parked GS400?
- Quick Question
- ES350 after oil change
- Help from the family please.....
- Timing Belt change?
- How to change GS300 02 Sensor Bank 1 Sensor 2 Code P0141
- Got a 5sp SC300 Last night - Suggestions on Fluids??
- Power steering question
- SC300 idle surge after tune up
- 02 is300 schedule
- Welcome RTGS400 as our new Maintenance forum moderator!
- Lifter noise on my sc400
- PCV Valve
