Check engine light on but?!?!? Cant pull codes
After I changed my sparkplugs and wires when I drive after awhile, check engine light turns on.
I jumped FE1 & E1 to pull the codes, but it just stays solid check engine light not blinking.
Unplug battery, grab a beer or two, hook back up...see if CEL light is still on.
There are 2 on the sc300 under the intake on the driver side
It could just be a bad connection at the sensor, the housings and wire gets very brittle over time and with the heat cycling they go through
The front one is a pain in the ***, it's above the ac compressor and behind the power steering pump. you may want to remove the ps pump
The other one is close to cyl #5 you should be able to inspect it without removing much
crwys
Jun 2, 2016 10:07 AM
dangt84
Feb 18, 2012 10:15 AM
