So I picked up a 1j that used to be in a supra and the guy I bought it from sold the converted supra harness, so all I have is a chopped up soarer harness that is missing quite a few clips... I need a new harness.
Any ways ive verified that the ecu is a auto soarer ecu.
The only soarer harnesses that I can find are for manual. Would it be possible to use a auto ecu with a manual harness? Ive read that the ecus are interchangeable. WOuldnt this mean that the harnesses are too?
If it were an Auto ECU and a Manual Harness, you would just opt out of a few wires off the 16-pin plug on the right, and also wire in the Clutch switch.
The 1jzgte Auto trans functions are consolidated on the ECU. Everything else is identical.
