Ugh, Blinkers not working....
I was cruising the other day and suddenly realized my blinkers were not working... I pulled over and saw a popped fuse, but it was my tail light fuse. Replaced it, tail lights work, but blinkers still do not. Fuse is good. Emergency Flashers work, just not turn signals.
Anyone have a clue? Or maybe a blinker wiring diagram?!
ive checked:
-fuses
-fender wiring
-flasher relay
Im stumped.
ive checked:
-fuses
-fender wiring
-flasher relay
Im stumped.
I spent the last 2 days ripping apart the fuse box, testing wire after wire, testing signal at the flasher relay...everything checked out. Then i decided i would take out my hazard button and clean it. Did that and bingo-bango blinkers work again. Apparently the hazard button had got stuck in a position where it wasnt fully on, but wasnt fully off. Another thing to look for if your blinkers stop working.
but glad you figured it out
