Suspension arm overhaul
Old Aug 27, 2014 | 12:00 PM
irondonkey's Avatar
irondonkey
Default Suspension arm overhaul
I'm looking to replace most/all of my control arms on the SC300.
I have been searching but I'm still a bit confused as to how many control arms the SC has. I come from the 240sx world.
I'm going to most likely be purchasing them from Advanced Auto, for just OE replacements.
AA always run deals where you can get up to 50% off an order, so why not.
Thus far, i'm not sure if i covered all the control arms.
from what i've gathered-
Front upper control arm
front lower control arm
rear lower control arm
front tie rods and tie rod ends
sway bar end links
((Rear traction/toe/camber arm???))
Has anyone else bought suspension arms from Advanced auto or any other parts store... and happened to have the part # for them? It would help lots.
Old Aug 28, 2014 | 08:16 AM
Blkexcoupe's Avatar
Blkexcoupe
In the front you can replace the LCA (most common item to replace), UCA, Inner and outer tie rod ends, and sway bar endlinks like you listed.
In the rear there is the LCA that the shock mounts to, UCA, traction rod, toe link, and rear sway bar endlinks.
Old Aug 28, 2014 | 06:22 PM
irondonkey's Avatar
irondonkey
looks like the front lower control arms aren't produced like the front upper control arm is.
Old Sep 3, 2014 | 08:11 AM
brandenGs3's Avatar
brandenGs3
Check out Battle Version and megan etc. parts are more reputable. plus it has a better feel.
PlotPoint
Jan 3, 2018 01:15 PM
chason
Jan 15, 2015 08:32 PM
2GSTony
Suspension and Brakes
Dec 9, 2014 10:29 AM
gsCrazy
14
Apr 11, 2009 09:32 AM
blkstealthpaid4
May 7, 2004 08:29 AM
