Whats up everyone, Figured I would start a build thread on my girl . I bought the car from Orlando back in early Feb 14 and drove it home to New Orleans. Talk about a fun drive. I was hesitant in buying her, as she needed a lot of work in my eyes. I bought her because of the reputation it had around the area and the damn thing was fast. 2 weeks into into it, the clutch went out. AC followed soon after. Then the fuel pump started to go. I even had the fuel send line bust on me. Starter had just recently went out. Of course I keep thinking man I must have bought a cursed car. Well things break as we all know. I am trying to stay the course here. I have done a lot over the months trying to get her right. I will post a mod list later, as its not on the cpu I on. I don't feel like typing all of it. But here are a few pics of her current state.
20K on engine rebuild
1JZGTE swap
R154 Transmission
New OEM seals
New OEM head gasket
Head was hot watertanked
5 angle valve job
New Starter
New valve stem seals
Resurfaced flywheel
Spec Stage 2+ Clutch kit
ARP headstuds
550 injectors
Masterpower turbo 70mm
Tial wastegate
Turbo Blanket
NOZZS Clear cam gear cover
Custom painted Valve and coil covers
Optima yellow top
Aeromotive fuel pressure kit
Aeromotive 340 lph fuel pump
Greddy FMIC
Synapse BOV
Greddy ic Piping
Greddy Boost controller
Greddy speedcut
3 inch piping to dual Magna flow exhaust
Titan Upper Radiator Hardpipe
Carbing Cooling Plate
Mishimoto catch can
AEM wideband
DEPO boost gauge
Autometer oil pressure gauge
APEXi SAFC2
Supra front brakes
Slotted front rotors
Tokico shocks
Supra lowering springs
Rear ARP Wheel studs
TRD MKIV Strut tower bar
HKS Turbo timer
HKS DLI
Body matched Headlight housings
Clear headlight lenses
White Oracle halos
Carbon fiber interior accents
HIC Rear roof spoiler
6K HIDS
95 taillights
Kenwood Double din Navigation / Bluetooth
Gauge cluster in working order
g35 Wheels
Carbon wrapped B Pillars
Working Heat
NRG Gold ebrake handle
New Ebrake leather boot
Lloyds Velourtex floor mats
Blox 470g Gold ****
Custom LED and climate control
Driver side weather strip replaced
Carbon wrapped door trim
Window visors
LED interior bulbs
Custom led footwell lighting
SEM Painted door panels
Dyno tuned by DV8 Resto
Reason: update
Here is a list of the things I have done since I have had her.
New Spec 2+ clutch
Resurfaced flywheel
19" g35 wheels ( temp till I get some varrstoen es6s )
Aero 340 fuel pump
New fuel return and send lines
velocity stack and filter
new couplers and tclamps
painted valve covers
painted coil cover
painted fuse cover
strut tower brace
clear cam gear cover
hks dli
wrapped coil packs due to break up
Installed Heater hoses
new low boost tune ( 14lbs, 409 rwhp on 93 oct on mustang dyno )
3m carbon wrapped wood trim
3m carbon wrapped misc console pieces
painted console
new lcd for hvac
autometer oil pressure gauge
hks turbo timer
Optima yellow top
92, 93 tails
clear sidemarkers
Painted headlight housings
Installed white halos
Installed clear headlight covers
fixed drivers window
fixed leds in door panels and key ring
gold shift **** and ebrake handle
new ebrake leather
new middle console leather
new starter
Immediate needs.....
Fix AC
Replace control arm bushings
new rack and pinion
steering bushings
Paint and body work
My wish list of course is extensive. Ill post my plans later lol
Just ordered some Battle version rack bushings. Hoping replacing those rack bushings will take care of the excessive play in the steering. Passing people is so sketchy because of the lack of response I have. As of now when I turn the wheel driving nothing happens, have to keep turning lol. Not to safe....
If I've never said it before...first off, welcome to CL. 2nd-Congrats, you've been busy w/ your SC I see? NICE! It's all about a piece of mine, I think you're heading in the right direction. Keep the updates coming.
Yep, no problem man. I just left Louisiana last November, I was stationed there for 3 years. I'll pm a salvage yard up "North" w/ over 50 acres of land, and the lot is in alphabetical order for all your parts needs!
Can you show a pic of the rear tinted tail lights please? Good luck with the solid bushings. I can't wait to buy mine. Mine looked exactly like that when I replaced mine with rubber ones. Wish I would've bought the solid aluminum.
And for the record, your sc looks absolutely stunning.
