1UZ spark plug torque?
Old Aug 23, 2014 | 02:51 PM
Biddles's Avatar
Biddles
Default 1UZ spark plug torque?
On LexLS tutorials it says 13 lbs. I've followed his guides before without problems, and he has detailed specs there stating "13 ft-lbs (180 kg-cm, 18 N m)", but a guy I just spoke to said 13 inches not lbs.... He however said triple check before torquing it to 13lbs as he thought it was a lot.
Anyone have solid info for me? Not trying to ruin my perfectly maintained engine. Just seafoamed everything however so I need to swap plugs. I haven't purchased shop manuals yet.
Old Aug 23, 2014 | 04:45 PM
t2d2's Avatar
t2d2
NGK says 18-21 lb/ft for my platinum plugs, which is even higher...
Old Aug 23, 2014 | 06:58 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
If you're worried about getting the threads stuck, use the anti-seize goo that comes with them. It does help against them getting stuck due to corrosion.
Old Aug 23, 2014 | 09:30 PM
Biddles's Avatar
Biddles
Well I torqued them to 13lbs, and that seemed like a lot to me for a spark plug. Thanks for the responses. I was just worried when someone told me it's not 13 ft-lbs that it's 13 inches. Big difference.
LexBrett
Mar 9, 2015 11:12 AM
94SC4
May 24, 2008 09:17 PM
sc_lang
Jun 24, 2007 09:01 PM
ShowGSLuVv
Performance
May 17, 2002 12:15 AM
