AEM EMS v2 Timing Problem NA-t
Old Jul 28, 2014 | 06:31 AM
suprakidxx's Avatar
suprakidxx
Default AEM EMS v2 Timing Problem NA-t
I have seen this in my search for my problem
https://www.clublexus.com/forums/per...-settings.html
but....it hasnt helped 100% for my individual problem
dizzy to COP using lq9 from mojo performance. all the dizzy wires check out from ecu to sensor and the grounds for coils and sheilding check out good. but my timing is static at -17 degrees while idling. if i rev it up it stays static even if the map calls for something different. if i change it to leading then it changes degrees.
Old Jul 28, 2014 | 08:20 PM
suprakidxx's Avatar
suprakidxx
ive talked with aem,rick,and searched google. no luck yet.
can someone point me in the right direction so i can check my settings.
coil phasing is 0 16 8 29 4 12 right?
this sucks
Old Jul 29, 2014 | 09:15 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you do realize that aem v1 and aem v2 are completely different right?
why not just use the numbers in the 6100 supra cal file. its attached.
unless Mojo orders them different but the one towards the firewall is #6 and the one near the radiator is #1 on a supra gte.
you have some settings wrong if its holding at static timing I have never even seen it do that.
Old Jul 29, 2014 | 01:43 PM
suprakidxx's Avatar
suprakidxx
Default just the person i was looking for
yes i do realize v1 and v2 are different. im just trying to find any info.
Id like to get a hold of someones working cal for lq9 and just taylor the fuel maps and timing to my setup.
we have tried trailing and leading on the coil/injector tab and one leaves timing static the other doesnt. but it still tries to build boost when just reving the motor. it will miss too.
ill post my cal and log when i get home.
Old Jul 30, 2014 | 05:22 AM
suprakidxx's Avatar
suprakidxx
today i couldnt get thet .cal my laptop has an older firmware than the ems. had to go back home and load that. tonight ill get it
Old Jul 30, 2014 | 01:02 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
Its harder actually to use someone elses map you have no idea what all has been touched.
I dont see why there would be much if any difference in the cal file for LQ9 vs a supra. its like TT coils sequential and there are 6 trigger signals from the ecu, except with lq9 there is no ignitor but the ecu really does not care about that. The only thing you should have to touch are dwell settings maybe which is not difficult.
Old Aug 2, 2014 | 03:02 PM
suprakidxx's Avatar
suprakidxx
you wont believe this but......injector clips 3 and 4 where swapped....problem solved.....now back to our regularly scheduled program.
1JZPWRD
May 10, 2013 11:36 AM
RLJ
Oct 29, 2012 12:23 AM
Ali SC3
Dec 4, 2010 10:14 AM
tonysc400
Oct 25, 2009 12:01 PM
PlatSilvSc
Jan 29, 2007 07:30 PM
