- peg leg
- Official Cx Racing Stuff Ic and more:
- TC Replacement??
- heater problem 93 SC400
- new clutch!
- 02 sensor
- 2jzgte w/ R154 swap question and concerns
- Mysterious coolant leak.
- Help with Heat!
- best intercooler for the money?
- struggle upon accel
- SC400 V8 Biggest Problem
- front cat delete, will it burn the rear cat?
- electrical gremlin help
- Wont start
- What oil do you use in winter?
- Well an AEM FIC be enough?
- need information on engine swap
- soarer swap missing plugs on sc body
- Aristo Trans - Manual Mode
- Car overheats only at high speeds
- sc400 not running smooth
- HUGE loss of power
- GTE swap time; some elec setup questions for gurus
- Speedometer quits working above 30..
- Please Help Identify This Hose On Power Steering Pump
- My SC 400 rearend went out
- the difference
- Should I flush my high mileage transmission?
- Na-t OBDII O2 sensors... advice?
- misfire at 6300-6500 rpms
- spark plug wires
- So my speedo broke today...
- Nosie when gasing it help
- Auto SC shifts hard into gear
- tranny issues....
- JDM Wiring for a 2JZGTE swap
- Egr
- Power Steering
- Anyone use a Greddy E-manage Ultimate on the V8?
- Mphs dont work on cluster!!!
- Wastegate spring
- DIY changing spark plugs SC400... I know, I know!
- need help (Trans Fluid Leaking)
- IS300 hedder on 1992 sc300
- SC300 1G to 2G alternator swap
- egr
- Why are all car shops shady?
- How much boost can stock 4.0 v8's handle?
- sc300 na-t help please
- heating problem
- Another Aristo swap
- transmission whine? or something else
- 2jz Ge Vvti From Is300 On A Sc400 ?
- 96 sc300 M/T Transmission mount questions
- Question for you Fuel/Engine Experts
- Which Ebay China turbo manifold to use?
- Piping Size
- JVTR aluminum radiator
- aluminum radiator explantaion
- singel turbo manifold problem???
- 92 SC400 Crossed Jumper cables - Battery Light?
- Is this My heater Control Valve
- tach and speedo incorrect
- Magnaflow 3" Dual Mandrel-Bent Exhaust w/ pics!
- How do i fix my temp gauge?
- 99 GS300 ijectors in SC300? need confirmation
- idle problem
- Hey! Wtf happen?!?!
- Little closer to the r154, few questions..
- Transmission Swap on 95 sc300
- Making a Mods List guide "need input" rearrange these and/ or add!~!
- ECU compatibility
- Please help= catalytic convs.
- Rattle rattle!!!
- What options does a SC400 have?
- LS400 headers ???
- Fernando's SC300 2JZGTE 6spd build
- trouble shifting when cold
- Polished Intake Manifold for a 1J
- How is this TurboEast Kit?
- idling rough when cold???
- K&N FIPK for is300 fit a 93 sc300??
- Help with deciding what clutch to put
- Need help guys sc300 is driving me insane!!!
- which flange on oil pan?
- no intake system for 97+ sc300? +turbonator
- Tune-up advice needed
- leaking power steering hose???
- 94 SC4 a/c
- 1jz on the way
- What Motor Oil to Use With 2jzgte?
- experiencing acceleration problems hope the experts had some insight
- serious maintanence question
- block off plate question
- Major Oil Leaks please help me!
- Need intake help fast!
- Help please (Starting/engine Problem)
- No heat when the car is NOT moving???
- buying a 1jz gte
- Thermostat ???
- Does a sc300 maf sensor work for sc400?
- to rebuild or swap, that is the question
- Few questions regarding Radiator Flushing/Draining
- 5-speed question
- Price advice on a fuel rail and injectors.
- Battery being stingy
- 2JZGE fuel injectors
- 5.7 tundra swap?
- quick ATF question
- Code DTC:31
- Crash sensor location?
- machine shop to do shifter extension
- R154 Tranny Questions
- 95 SC400 belt squeeks
- seco clutch kit?
- Fuel Line OD
- Draining my coolant...?
- Unforseen Problems
- Suggestions on 02 sensors?
- Need Help 95sc300
- Idler pulley?
- sc300 racing in overdrive?
- Resetting check engine light
- JoeZ intake pipe on our SC
- Fuel cut at 125mph
- Car wont start , ahhhh!!!NYC
- Sc300 VVTi engine setup and wiring in another car
- Maintenance Question...
- pcv valve
- 2JZ swap
- engine swap
- dakota digital tach adapter? anyone else have one?
- 1998 Sc400 exhausts nd intakes
- No heat
- Pulls Strong Under WOT Until 5K - Lexus Is Stumped - Need Ideas!!!
- Heater core bypass??
- jdm engine importer feedback? (good, bad, ugly?)
- compression ratio, help!!!
- 94 SC400 Heater Control Valve?
- GTE Swap Cluster for >99 SC300
- pics of my aristo swap
- decisions desicions....
- fuel inj cleaner?
- 1JZ Bypass Valve Limiting Boost? Yep!
- Fixing a leaking cat?
- where can I get a air flow meter?
- sc 400 running on 4 cyl HELP!
- Mobil ATF+III
- Changing oil pan gasket.
- ScNoobie need EXPERT advice on SWAPS w/ pic
- What Fuel Pump to buy for replacement? (92-SC400)
- Steering Vacuum Lines
- SC300 dies when cold
- SC300 seafoam DIY page?
- Has this ever happened to you?
- motor swap ?
- Car runs rough and stalls at idle after spark plug,wires,cap, and rotor change
- How do you know if your torque converter is bad?
- power steering pump
- Blinking O/D light???
- Power Steering Reservoir relocation???
- the most elusive pinout in the world?!
- sc300 swap
- Open Headers?
- 1J runs like crap at WOT
- Cruise control delete??
- exhaust sounds
- wanting to turbo my sc300
- Key wont come out
- 1UZFE valve covers powder coated in wrinkle black.
- Is this the ignition or tumbler switch???
- Removal of our EGR C#$p!!!!
- Soarer R154 guys check in! Need quick help!
- New Guy w/ Question
- sluggish?
- '98 Supra motor and tranny in a '92 SC300
- SC prob..again
- injen intake
- My 94 build up!! NA-T
- Error code 29 NEED HELP!!!
- New record lexus tony performance 8.74@162
- Rebuilding my A340
- RPMS go up when I turn the steering wheel
- What fluids do you all use?
- Car Hesitating
- Part 2: Build Results and Upgrades
- downpipe fitting
- if my sc300 is a 97'?
- trouble identifying an underhood part
- cams
- BFI, CEL and WOT
- 1jz-gte swap completed *pictures!!!*
- anyone have experience with this intake?
- stock whp
- No Cat down pipe
- Ahhh Help!!!!! Tranny swap problem
- SC 400 Engine swap
- Metallic substrate cats
- For those who know how to read Smog #'s.
- sc300 95
- sc300 sc400
- Power Steering
- maxxed out stock 550cc injectors
- Gated shifter upgrade
- 2jzge sc300/mkiv headers help asap!
- Electrical Ghost: alternator, ground harness, or other?!?! HELP
- Using an IS300 LSD?
- Idle problem, plz help
- Sputtering!!! Help!!!
- sc400 power steering pump removal??
- Help New Lexus Owner No Heat and Need Mechanic
- ***sc4 trannys***
- tranmission on NA-T for Auto?
- Cheap intake solution!
- soarer body plugs not there
- putting supra turbo parts in non turbo sc300
- No Heat!
- My new project... NA-T here i come
- Problems with Flexalite electric fans
- What Supra Parts fit the SC?
- Time do decide 1jz or na-t
- 2jzgte sc300 & 400
- EGR Question...
- any advise
- Is this a good deal on timing belt/wp kit?
- more power
- wow stupid question, 2jz/1jz turbo manifolds
- 1jz help
- 1995 SC400 Neo install help please
- Failed Emissions?
- Air To Water Intercoolers
- Crankshaft Pulley
- Should I be afraid of a SuperFlow dyno?
- exhuast leak help a brotha out please
- how to shut off fuel pump? HELP!
- Going Single! ohh fun... Choices
- Help please!
- Need advice (Engine Swap ???)
- Help Crisis!!!!!
- Upgrade t04b turbo
- Air intake tube for '93 SC400?
- TRD high-flow drop in filter
- Please help.
- Thinking of Nitrous
- 2JZGTTE Coil Over Plug question
- 1998 SC300 K&N Air Filter ????
- Help me locate air conditioning service port (suction)
- throttle body
