more power
if you had an egt gause you can see where timing advance can cause damage. most people dont advance their timing around here but rather retard it a bit. the case is most poeple go turbo and dont care about NA.
the stock advance of 10* is at idle. the total advance while operating on the motor will actually be more.
i know that on some of the VW and 4age atlantic motors ive worked on the idle advance was at about 18* and total advance was in the 35*ish degree range.
forcefed86
Performance & Maintenance
11-30-07 09:36 AM
