- Acceleration problem....Help please.
- Timing belt kit for 95 sc300?
- water / meth injection on supercharged v8 - coming soon
- Sc300 stock fuel pump specs?
- Not down shifting with ECT off, is this normal?
- Loud Moaning Noise
- Newbie Upgrade question...
- tony performance new record 8.59@163mph
- Help removing 3rd cat
- Horn not working!?
- 1jz head is about done NEED HELP WITH SINGLE TURBO
- Engine gasket kit?
- urgent help with injecors
- turbo oil line question
- My Cheap Solution for those who have broken climate control and Electrical Ghosts.
- camshaft replacement question please help!
- Blitz SBC i-D III Spec-S okay to use on stock 1JZ twins?
- turbo manifold question
- Need replacement boot for SC300 manual shifter
- Something seriously wrong? Motor pulls like crap at high rpm
- 1JZ going single is delayed...
- $5k for machine work?
- Driveshaft bushing compatible between sc400 and ls400?
- 97 SC400 slight whining at full throttle
- Wheel Hop
- Car is running like crap after putting in gumout fuel cleaner.
- gathering up parts for 5 speed conversion help!
- Opinions, cat or resonators
- I had to push my car yesterday, today I don't...
- How do I remove the 150 AMP ALT fuse on sc400?
- 1jzgte o2 sensor location
- Anyone have troubles with their fuel pump ecu?
- 1jzgte-vvti feedback
- Do you drift??? Do you drive your car to the edge?? >>>
- how to tell if my Fuel Pump ECU is bad on my SC400?
- 1jz turbo ?s
- how do you guys feel about this turbo kit? not ebay!
- More clutch engagement woes
- 1JZ power steering question
- 1jzgte-vvti hp
- help with which mount to get!
- Ultimate 1uzfe W58 Conversion Thread! (LOTS OF PICS!)
- Compressor or Clutch Locked Up on my AC system?
- Diff Problem
- My new air intake!!!
- how to install a greddy catch can
- Water Bypass Valve?
- Clutch pedal low to floor with SPEC stage 3?
- what is the best computer mod ?
- gte dyi??
- 1UZFE Kelford Cams
- 2jz non turbo into sc400
- DIY, Removal of cluster, and Redo of lighting!
- do they make
- Removing Alternator
- Help! have 1jz swap questions i cant find answer
- 1jzgte-vvti cuts off
- Making an intake tube to go with a BFI?
- sc400 kickdown lag
- SC300 BFI DIY w/pics
- Help!! Please help!!!
- Top speed with R154 and Supra TT auto LSD?
- wierd cooling problem
- question regarding 1JZ swap
- ~Custom 1JZ Coilpack Cover Pic Request~
- So i believe i blew my engine help me out here
- Tps sensor location?
- checking iac valve
- Where to Start?
- 1995 sc400 5 speed conversion question
- power steering cooler
- Easiest way to swap in a TH400 trans?
- Just Got My Clutch Today
- Could a Vacuum Leak cause this?
- Looking for No. 4 Solenoid Wiring Diagram
- ok so need advice about this toyota mechanic
- SC300+Aristo+SAFC made easy
- Swap complete! Also A/C questions.
- Both Door Handles on Passenger side not working How do i open the door?
- So.. I got a teaser of my clip..
- Overheadting help
- Best performance mod(s) for $1000?
- $50 to scan and clear my transmission codes/ 92 sc3??
- NO Power to Climate Control Center
- hard turn and now car bucking under any load
- Loss of compression!!
- Car buckle/ sluggish/ lags
- Another Starting Issue, New battery?
- Alternator/Battery car issue? Weekend car
- sc4 turns over and over but wont start
- Code P0401
- R154 auto to manual swap engagement problem.
- Video - 1992 SC400 > W58 Conversion...
- Nice Tips for Stock Catbacks
- Stock Plug Wire Brand
- Code 71 egr Any opinions?
- Do you only use 93 Octane in your SC300?
- thermostat housing problems & Tstat question
- My crank pulley need to be replaced...
- Can you guess whats comming up soon?
- Removing Stock Air Filter
- Air Sucking Vacuum Issue after Starter Replacement
- Exhaust Advice
- !@#$@!#$#@!!!! I bent the shifter lever
- Help me piece together my na-t project
- Important Vacuum line question PLEASE HELP
- Boosted My SC
- Question regarding vacuum lines
- '92 SC400 sqeeling noise
- Bad Head Gasket Picture
- Motor mount put a hole in my header
- Power unlock works, but not power lock
- First major mod
- Where to buy the MAP-ECU?
- Why?
- what shld compression be boostlogic headgasket
- Fuel system upgrade, which route?
- What kind of a gasket?
- Help with relocating fender harness
- CX RACING ALuminum radiator? SC/Supra
- SC400 Differential Cushions/Mounts
- jzx90 harness?
- i am going to put a chevy small block 350/350 turbo in my sc
- Denso Universal 02 Sensors
- 92-97 same as 98-2000 Exhaust on SC300?
- OEM Wiring Work
- My Billet 62 low boost dyno results....
- Flex Coupling
- My Sc300 BATTERY LIGHT!
- Need a little help yet again
- Gas pedal sticking at wot
- 1JZ Head bolt torque & sequence
- Nitrous Install
- Electrical Problem (Fuel)
- Vacuum Help with SC400.
- 1992 1UZ-FE engine Manual says set 0 for timimg,but here i read 50 degrees.Which is i
- SC 400 exhaust
- stock 2jzgte twin turbos on Sc300 2jzge?
- A/C compressor interchange?
- Ugh, i cant believe this is happening.
- Auto to Manual tunnel mods?
- Manual Boost Controller Install?
- What turbo manifold to use?
- 93 sc400 timing belt change?
- mk3 shaft with stock sc rear is too long for r154 swap
- AHHH so Frustrated, I need some o2 Sensor adapters
- Roll bar pics
- teaser AP Titan II exhaust
- do I need all 3 o2 Sensors?
- Belt or Chain
- 1997 sc400 transmission oil
- so i got to the tx2k9 early and since there was no wait i put my car on the dyno...
- need intall guid for ic pipping on ge motor sc300
- Sc 400 engine ??
- 1jz swap into a 2gs ftw or ftl?
- Temporary exhaust fix?
- My Manual SC400
- Spec 3 or Spec 3+ With my NA-T set up?
- SoFlo part II //LRD dyno pull
- Thumping noise when I shift??
- Alternator replaced : A little tip
- Engine Dies While Driving And While Idioling
- Exhaust fumes question?
- South Florida Dyno numbers Pt. I
- Turbo for VVT-I
- 92 SC300 CEL - #17 (w/o OBD2) need help
- TH400 Tranny question (High Horse Power Guys)
- Engine Bay Reconstruction "Johnny Number 5"
- Little teaser - You SC400 guys will enjoy this even more!
- 99-00 SC300 picture request, engine, header
- 92 sc400 water pump? :(
- Torque converter opinion needed
- This is why you don't buy mods at 3AM.
- 1jz Power Steering Pump Help
- Spring plans! <Transmission help>
- SC400 Brake Calipers
- Really quick w58 swap question
- Heat Wrapping your Cold air intake tube
- T3 super 60 on a 1jz-gte. Too small?
- TPS sensor clip = Car not running right
- Need help please!
- fuel injector cleaner ?
- No fire. need some help.
- sc400 injector upgrade
- For the love of...uggghhh, starter motor part number?
- Broken Speedo Plastic Gear or worse?
- Lightweight flywheel...streetable?
- Suggested drive belt and source?
- Newly Owned SC300 Questions Clutch Flywheel question HID
- Headgaskets need to be changed, anyone have the shop manual for 1jz-gte?
- Relocating harness ?'s
- sc300 1jzgte 1/4et
- Exhaust spec Questions
- Cost of Machine Work
- Fuel Filter
- been thinkin
- biggest cams
- Flex Coupler Part number
- A 1jzgte swap in a 92 sc400 and whats needed?
- Battery draining problem
- DIY knock sensor replacement
- 1jz swap question?
- Installing Gauges, anyone know what wire to use?
- Differential gearing question
- 1jzgte oil leak around oil filter housing
- Some questions about battery, and ldle
- Did the Water pump/Radiator/Timing Belt today
- Help needed badly!!
- radiator?
- IACV setup on FFIM?
- got my head today
- LSD for 1997 SC300 what size? Need help!
- name the bov of the supra
- More issues than I thought
- HELP!!! What this noise????
- trans prolbem need help
- Help in decifering mysterious warning light?
- How much $ to go fast?
- OBX Header...Buy or Pass???
- what manifold will clear dist with t67
- whats the most hp stock bottem end can hold
- Need help
- help with timing belt
- 2jzge tensioner question
- checking codes
- Cam gears for a 300
- Can someone help with diff question????
- what seals/gaskets 2 change on tune up
- missfire
- Code P0510: TPS Problem
- washed engine bay - strange problem. need the experts
- Where to fill up transmission fluid
- SC300 Oil Capacity - Technical Service Bulletin
- intake trble
- ABS and TRAC lights on
- 94 SC400 fan belt
- 1jz automatic transmission rebuild?
- 1uz manifold question.
- Fuel pump stays on with key off.
- 5 speed and an Auto ECU?
- Clutch stuck engaged
- Help with diff fluid change on sc400!!
- 94 USDM GTE in 92 SC300
- aristo 2jz gte vs 1jz gte
- SC400 V8 engine that's as fast as Bugatti Veyron!!
- custom exhaust from Concept Muffler
- *Project Log* SC400 1uzfe to W58 5sp conversion
- Better benefit or downfall from straightpiping??
- Injector Pictures.
