- To replace or not replace plastic ATF hoses
- Front Brake Rotor Removal Difficulty
- cargo box problem
- After all these years ..
- Transmission has lost power/pressure
- RX300 Climate Controls not working
- Need to know what hose this is
- Parking brake cable snapped
- Right front wheel grabbing can’t move SUV
- AC blowing hot
- The issue with my Lexus multiple things stoped working
- New Take in IACV Cleaning
- Noise -> Lost gears -> Would not engage
- AC temp control
- California Compliance??
- Help with overload needed
- 2002 RX300 High idle
- Troubleshooting a particular combination of body electrical issues
- Ticking in center dash when I turn on the AC.
- VSC light on
- What frame is the same as a 99 rx300?
- Help!!
- Valve Cover Gasket job. What else?
- Buzzing sound from drivers side dash 2002-RX 300
- Thottle Body Vacuum Hose Diagram
- Need advice re: alternator
- Winter break road trip!
- Left Rear Caliper Failure
- And odd combination of display/function glitches
- Single click, then lights go out when trying to start
- 1999 RX300 Cig and Power Outlets No Power
- Brake light switch keeps failing
- Random limp mode
- Strange roof leak
- What is this electrical computer/amp?
- 1MZ-FE engine burning oil
- Is my factory theft system performing correctly?
- Buzzing in steering column at start up
- Upgrades over the last few months
- Brake upgrade question
- Better Rear Sway Bar Links for AWD Models
- Tape and CD buttons not working after bluetooth install
- 1999 transfer case toast
- Need any ideas on a good trouble code reader
- RX300 rear valve cover (aka cylinder head cover) gaining access for tightening only.
- Cabin Filter Upgrade 1999-2003 RX
- JDM Engine
- Turn Signal/Hazard lights not working
- New member engine light and other issues
- headlight assembly
- Blower Motor Resistor/Control Module and Blower Motor
- Anyone playing with hydrogen
- Oil Leaks
- dashboard message
- New alternator blew fuse
- “p” and “d” on dashboard do not illuminate when in either gear
- Low rpm on D
- Radiator replacement
- 200 RX 300 headlight & fog light problems
- Crank, no start
- RX 300 headlight adjustment
- Brakes
- Will 2001 RX300 Charcoal Canister fit a 2000 RX300?
- Key Fob Confusion
- replaced knock sensors now having shifting issues
- Transmission rebuild inquiry
- Ect snow randomly comes on by it self
- 2002 RX300 Maintnenance-timing belt, water pump, and transmission filter ?????
- Rx350 dash light
- Knock and oxygen sensor replacement question...
- Coolant leak 99 RX300, need help sourcing!
- Wind sound when play a CD on RX 300
- Can't result for emission test
- Baffling parasitic draw mystery
- Timing Belt Hydraulic Tensioner Oil source?
- 2003 Lexus RX300
- Slight stumble on idle
- 1999 RX300 Rack and Pinion Steering Bushing replacement
- 2000 lexus rx300 wont start with out obd2 scanners
- Front brake- Centric?
- Passenger Side Air Bag Cover Question
- 1999 lexus rx300 dash kit
- OBD II DLC Pin-Out Diagram Please
- Trac ande VSC Lights On After Scanner Use
- Is this where I introduce myself? Hey Everyone!
- Front windshield wipers, do they have a park position?
- 2000 model I’m stumped
- NO AC on my 2001 RX300
- 2000 RX300 Left Side Window / Lock Master Module
- Key Question
- Having lots of electrical problems 2000 RX 300
- Orientation of oil drain plug gasket that is part metal/part rubber
- Weird Noise when driving. Sounds like its stuck in overdrive
- Brake torque
- No power please help!
- P0325 and P0330
- o2 Replacement
- Folding Seat Latch Release Handle for '99 RX300
- Failed upper strut mount?
- P0302
- transmission issues
- Body ECU repair?
- 03’ RX300 suspension squeaking
- Heater mystery
- Front Windshield Wipers Non Stop
- Burning Oil
- Fuse for theft deterrent system
- Thank you RX forum!
- 99 RX300 head gasket
- Air bag question
- Placing nonheated windshield into RX300 that had heated windshield
- Overdrive
- RX300 Wheel Bearing or Something Else?
- Carbon fiber wrapped interior wood trim
- FREE RX owner
- Engine stumbles when hot
- Oil filter question ?
- New lights for roof rack and grill
- Brake Lights (not CEL) Stay on When Engine is Running
- 2000 RX door locks controlled by fob
- 2001 rx 300 awd: Transmission: T-1V or WS
- Retractable Cargo cover
- 03 Lexus RX 300 starting and transmission issues
- Door lock actuatators unlocking multiple times when driver door closed
- 2002 Lexus RX300 - P1150, P1346, P1346
- 1074 code
- 2000 RX300 - Rear Side Body Mark Lamp Assembly Fastener
- Keyless entry program successful but doesn't work
- Instrument Cluster Gear Selector Indicator Light Replacement
- Towing suitability?
- Headlight Leveling Not Working
- Cranks but won’t start
- 1999 RX300 Rough Idle
- fixer upper rx300
- P1325 and P0300, some help please
- Liftgate cable broke
- RX300 wiping ecu HELP
- Power Windows
- Interior air ducts
- P0141...but it’s not the O2 sensor
- 2001 RX 300 HID Low Beam Lamp
- Persistent CEL 171 - need help
- Axle Seal Leak?
- Water leak '99 rx300
- Anyone have an idea of how to repair Antenna Motor Assembly?
- P0441 on 2001 RX300
- Flashing VSC Light
- Costs for maintenance services
- Odd stain appeared
- 99 RX ground points?
- 1999 RX300 - Whats this part?
- Help coils keep blowing
- Front Brake Pads?
- Cam Sensor Problem
- Roof Rack Crossbars and Roof Top Tent Options
- What to do? High mileage RX300
- 99 Rx300 trouble
- Transmission problem
- Error code P1663, P1346 and P1351
- Lightbulb warming light on, but all bulbs look good
- Po440,441,446
- OBD 171 question
- 2000 lexus rx 300 transmission problems
- Time Capsule
- Should I buy a 2002 Lexus RX300 with 240,000km?
- 2000 RX300 total electronic shutdown
- SRS Module removal/replacement- Where is it?
- RX300 Engine Splash Shield lower outer bolt plastic screw retainers
- Transmission blues - need advice
- Rx300 headache
- Need to test the Alternator Fuse on an RX300
- 2010-2015 LEXUS RX300 RX350 18 wheels fit my rx 300
- Right front AWD axle question
- 1999 RX 300 valve cover gasket
- Cleaning the RX, also a question
- Key Immobilizer
- Sudden Unintended Acceleration!
- Bad ground in headlight system
- 1999 rx300 won’t start, security light going nuts, key won’t unlock/lock doors
- Keys Not Working
- Spark Plug Replacement
- Finally got around to fixing driver seat cover, before and after
- What part is this?
- RX300 ECU repair?
- 2002 RX300 Neutral Safety Switch removal
- Valve Adjustment Required?
- easy Knock sensor replacement relocate bypass knock sensor
- Whining noise with RPM first start of some days
- Oil in number one spark plug shaft
- Thermostat DIY?
- Key Fob Not Working
- Window and lock switch LEDs 02 rx300
- Replacing rear wheel bearing assembly! Difficulty level?
- Shift cable replacement
- climate control recircualte air default change to fresh air?
- DTC C1336 w/ Trac Off and VSC Lights (On Steady)
- Vibrating/jerking when shifting at standstill, now won't engage in reverse..
- Can't move R, D, 1, 2 after adding Lucas Transmission Fix
- ABS light wont turn off and firing zero codes
- Finally, an updated radio for the gen 1 RX300! Thoughts
- simultaneous p1300, p1305, p1310, p1315, p1320, p1325
- 03’ RX300 Rear wiper arm replacement
- Jerking
- rx300 cant move drive but reverse only
- exhaust flexible coupling. Necessary?
- 45 miles from home
- Skid light and beeping -- worn rack bushings
- luggage racks
- 2002 rx300 drivers side defogger
- Akebono vs. Wagner Thermoquiet - stopping power
- Car occasionally shuts off after coming to an idle state
- How to replace the brake light switch? HELP ME!!!
- Replacing antenna trouble help needed
- RX300 TONS of trouble codes help
- Removing the Coolant Reservoir
- In LOVE with my first Lexus!! But - it has some annoying habits
- kinda doggy acceleration
- Power window
- 02 rx300 aftermarket antenna
- Low beams non functional, High beams dim
- 2000 Lexus RX300
- Lexus RX 300 owners pictures showcase
- Misfire help
- 2003 RX300 stuck in park (HELP!)
- Transfer case or Transmission?
- Air vent issue
- HELP! 99 RX300 Nakamichi amp
- AC condenser
- 2001 Leaky axle seal?
- Cannot get long life coolant anymore, can I mix?
- 01 Rx300 On/Off Switch Under Dash?
- Vehicle seems to be hesitant when in an incline but drives fine otherwise
- transmission
- Rear hatch handle no longer spring back to original position
- 2001 Toyota Harrier 3.0L V6 knock sensors with the two fault codes, P0325 and P0330,
- 2002 rx300 p0330
- Have a Battery. Can I Use It?
- sunroof is driving me crazy
- Squeaking timing belt
- Relay Location for Rear Defroster????
- Gas leak from the injector area
- clock resets then battery dies
- 2001 RX300 W/S washer hose leak.
- Battery draining
- Won’t shift into last gear after reaching running temp
- Possible vacuum leak 2000 Rx300
- VVT-I oil control solenoids
- Oil drops on garage floor any info would help...
- Need help! RX300 front mount bolt getting stuck
