ABS light wont turn off and firing zero codes
Old May 28, 2020 | 02:59 PM
KWilson's Avatar
KWilson
9th Gear
Default ABS light wont turn off and firing zero codes
Has anyone had an ABS light that would not go off? It's not throwing any code and the repair shop has no ideal on what is causing the ABS light to stay on.
I've replaced the rear wheel bearings and the driver side rear axle which had a broken ABS ring and it still stays on. I've also replaced the ABS module and still nothing.
I found a guy online that said others had the same and they showed a video using a jump wire under the hood and removing a few fuses while pumping the brake 8 times which would remove the light.
Has anyone else tried this?
Old May 28, 2020 | 03:34 PM
maxSteel's Avatar
maxSteel
Lots of ABS threads here.
Try this one: https://www.clublexus.com/forums/rx-...-solid-on.html
tom8757
Dec 15, 2012 05:51 PM
Toshihiro
Suspension and Brakes
Feb 4, 2012 05:20 AM
Patsum
Nov 1, 2011 07:38 PM
onslaught
Oct 5, 2009 03:17 AM
