Low beams non functional, High beams dim
Old May 4, 2020 | 09:05 PM
Phantom410's Avatar
Phantom410
Default Low beams non functional, High beams dim
Hello,
My headlights ceased to work on my 99 RX. First tried a replacement relay, did not solve the issue. I then tried hot wiring where the relay went by bridging connections (as shown below circled in red) and it brought the low beams back, but no dice on the high beams. Any possible idea as to what is wrong with this system? maybe a dud relay replacement (the relay replacement is the blue pulled out in the box) , bad ground, or is there a headlight ECU that might be toasted?
Thanks in advance!​​​​​​​
Old May 5, 2020 | 12:44 AM
carguy07's Avatar
carguy07
See if power is making it to the relay. Headlight switch if it's not?
Old May 5, 2020 | 08:11 AM
salimshah's Avatar
salimshah
25 Year Member
The Fuse Panel does not look spiffy (it can be the flash that makes it look worse than what it is). You may want to unbolt it and have a look from behind as there may be a bad case of corrosion. Contact cleaner can remove surface corrosion.
A minor fact that is usually overlooked is DRL has an input from brake pedal.
Salim
Old May 5, 2020 | 01:30 PM
Phantom410's Avatar
Phantom410
Post
Power is making it to the relay, hence why the connection bridge works. (between the red circles) i am going to check the other slots for corrosion while im in there. Where is the headlight switch located to check/test? Many thanks
Old May 5, 2020 | 01:32 PM
Phantom410's Avatar
Phantom410
Really? Never knew the DRL has an input from the brake pedal how would I go about testing that out? is there a fuse/sensor associated with this? Thanks!
Old May 5, 2020 | 05:31 PM
Margate330's Avatar
Margate330
Hi,
Do you have Hids or No Hids?
Old May 5, 2020 | 07:07 PM
salimshah's Avatar
salimshah
25 Year Member
Back then there were still a few drive-in theaters. The auxiliary (foot) brake when applied would kill the DRL.
Salim
Old May 5, 2020 | 09:48 PM
Phantom410's Avatar
Phantom410
99 RX's do not have the HID's, only halogens. Don't feel the need to convert quite yet either
Old May 6, 2020 | 03:45 AM
carguy07's Avatar
carguy07
I mean the power to trigger the relay from the headlight switch.
Old May 6, 2020 | 05:47 AM
Margate330's Avatar
Margate330
... is there a headlight ECU that might be toasted?
The non-HID has no headlight ECU so that will simplify things a little- at least on the 2002 schematic.
It shows jumping the relay the way you did forces on the Low Beams but maybe someone has a 1999 headlight schematic to compare.
Also, there is a DRL No. 4 and a DRL No. 3 Relay for high beams and DRL's circuit but the 2002 schematic is all I have.
Returd
Nov 22, 2018 05:47 PM
Phantom410
Aug 6, 2018 03:43 AM
Limodrivr
RX - 3rd Gen (2010-2015)
Mar 27, 2018 11:06 AM
silva1181
Lighting
May 12, 2017 01:41 PM
SebaPR
Dec 8, 2014 09:40 AM
