P0302
Old Oct 4, 2020 | 06:36 PM
Ronvern's Avatar
Ronvern
Default P0302
I have a 2001 rx300. I had a knock sensor go bad. I replaced it and now have a p0302 misfire. I changed the plugs, switched the coil and injectors around and still not working. At speed the light turns off, but at idle and lower speeds it flashes. I dont know what else to try. Any advice would be appreciated
Old Oct 5, 2020 | 08:08 AM
salimshah's Avatar
salimshah
25 Year Member
This is for cylinder #2 ... [your in luck as it is the one n the front .. radiator side ..] towards the passenger.
Plugs should be changed around 110K miles with OEM [you can try others but if you are having issues, stick with the reliable]. Share with us the swap procedure you did and checked.
Also look for loose vacuum lines .. the vehicle is old and reconnecting hoses some times have a problem. Also look at the plumbing of hoses .. a member recently reported a wrong hook up. All these issues arise after a repair is done. So retracing the footsteps would help.
Salim
Old Oct 5, 2020 | 10:14 AM
Ronvern's Avatar
Ronvern
I changed all the plugs and swapped out the coils and injectors from different cylinders. It runs fine when at speed but idle is rough. When at speed the engine light stops also. When I pull the #2 coil wire it doesnt change how it runs (same with injector wire)
Old Oct 5, 2020 | 02:29 PM
salimshah's Avatar
salimshah
25 Year Member
Which plugs did you install? NGK/Denso irridiums?
Vacuum plumbing?
Salim
Old Oct 7, 2020 | 12:39 PM
Ronvern's Avatar
Ronvern
Default Update
So I changed them with cheaper NGK plugs. I did a compression test on #2 #4 #6 an#2 is 75psi, #4 is 125, and #6 is 170. Plugs are all really black. Should I assume headgasket?
Old Oct 7, 2020 | 08:55 PM
salimshah's Avatar
salimshah
25 Year Member
You have diagnosed your problem. For the question you ask, you will need to do more investigation, I would suggest visit a mechanic who can perform various tests and confirm that the problem is above the piston or not.
Salim
Old Oct 9, 2020 | 03:21 PM
Ronvern's Avatar
Ronvern
Sorry for taking a bit to respond. With the p0302 and p1305 code plus 2 cylinders running low compression am I right to thing head gasket. It does give off some white smoke on cold start also
Old Oct 10, 2020 | 08:49 PM
salimshah's Avatar
salimshah
25 Year Member
A good mechanic will be able to confirm by lowering a camera, doing compression leak down tests and even oil-coolant check. The bad compression can be due to rings as well. So your conclusion may be right but it might be better to get confirmation by testing.
Salim
Lexus4321
GX - 1st Gen (2003-2009)
Oct 16, 2020 01:38 PM
syracuse
Mar 29, 2014 09:34 AM
bwilmoth
Jan 17, 2012 11:34 AM
shadow12
Apr 22, 2011 10:01 AM
desantura
Oct 27, 2008 08:57 AM
