2003 RX300 stuck in park (HELP!)
Old Apr 29, 2020 | 10:22 PM
Is200tieu's Avatar
Is200tieu
Default 2003 RX300 stuck in park (HELP!)
Haven’t driven my RX in a couple months because I bought a 3IS. It is now stuck in Park gear and will not come out of it at all. This has happened once before and I had to pop the cover that had the shift interlock override button in it. When I went to put the cover back however long ago, it got wedged and is now completely stuck into the shift column surrounding piece (attached photo on how wedged it is) any tips?
Got it. Thank you for the help!
Old Apr 30, 2020 | 04:15 AM
salimshah's Avatar
salimshah
25 Year Member
First determine the reason that you can't shift ..
Interlock or wedged cover?
Interlock can be locking you out due to fuses or bad brake switch. [check rear brake lights on application of brake].
Cover .. the trick is to reverse the process ... if a corner was pulled, try pushing. Check prices of replacement and just use dremel to saw off [worst case].
Double posted ... The fuse you need to check is the brake fuse [only after confirming the brake lights dont light up]. The brake switch has limited life and a few members have reported issues with it. The fuse is fairly robust, unless something physically goes bad with the wiring or an accessory is tapped into it.
Salim
Old Apr 30, 2020 | 09:35 AM
Is200tieu's Avatar
Is200tieu
Salim
The brake lights do function correctly. Could it still be the fuse?
Old Apr 30, 2020 | 10:43 AM
salimshah's Avatar
salimshah
25 Year Member
If the brake lights [not the tail lights .... just confirming] work then the fuse is good and the interlock relay should release the lock.
Do you observe the cover preventing the movement?
Or the side button on the lever [going by memory here ... newer versions have a shift gate and first gen had a side button release].
There is also a PRND switch on the transmission.
And at least two members have reported linkage problems ... but with the cover off, you should be able to see that [only top end].
Salim
Old Apr 30, 2020 | 10:58 AM
Is200tieu's Avatar
Is200tieu
Salim
Correct the brake lights work glow when I press on the brake pedal. This has happened before but I popped the cover for the button and it worked. Now the cover is wedged and stuck. I’ve tried to take a hammer to it and it still won’t bulge. Was wondering if I could take it apart and push the interlock button with it all apart
Old Apr 30, 2020 | 02:46 PM
salimshah's Avatar
salimshah
25 Year Member
Cant suggest much other than ice-pack, dremmel, leverage. You can try cutting a slot to relieve the tension and give yourself some flex.
Incidentally, it should just be the square black piece that needs to be removed, but your challenge is different now.
Good luck man and I hope there is no collateral damage by an errant blow or a cut.
Salim
Old May 1, 2020 | 05:48 PM
Margate330's Avatar
Margate330
Hi Is200tieu,
If you get tired of messing with it there are plenty of complete shift assemblies on ebay for $50 and up.
Marcell
18
Jan 19, 2021 07:29 AM
Stevedud
RX - 3rd Gen (2010-2015)
Jun 5, 2019 11:53 AM
Rosson3ri
Jun 22, 2015 12:15 PM
randomwalk
Dec 2, 2010 03:01 PM
2006lx470
Feb 5, 2006 05:19 PM
