45 miles from home
Old May 25, 2020 | 06:27 AM
G1RX300B's Avatar
G1RX300B
Default 45 miles from home
30 hour, overnight, 600+ mile roundtrip to purchase new motorcycle. Wife drove 2000RX with 263K+. I rode new bike.
45 miles from home, wife pulls to shoulder of highway:
1. RPMs are going well into 4-5K range
2. no power seems to be getting to the wheels
3. after being on shoulder, can still shift into every gear, but no motion from transmission
Call tow service. ~90 after initial call —now at closed service center— the tow driver
1. reverses RX off the tow ramp
2. drives it to parking spot
WHAT????
Tow driver said "sometimes transmission plates can get overheated and need to cool off."
WHAT???
Dozens of 500+ mile trip over the 14 years I've owned this vehicle and never has this happened.
Things to note:
1. after reversing (back) up the slight downgrade we just travelled to get to motorcycle seller's driveway(~320 miles into trip), there was a strange "whirring" sound after shifting back into D.
2. heard same "whirring" as we left for home with slight delay in shifting. Noise —and delay— went away after ending warmed up.
3. since returning home, I've yet to check for codes
4. "HOT" transmission fluid level seemed fine upon checking. Admittedly didn't check "COLD" level.
Questions, comments, concerns and anything else considered are all most welcome. Thank you.
Old May 25, 2020 | 03:12 PM
maxSteel's Avatar
maxSteel
What kind of bike did you get? I'm actually surprised you didn't trailer it.
But I suppose if you had you'd be blaming that for the issue. Were you ultimately able to drive the RX home?
Old May 25, 2020 | 04:04 PM
salimshah's Avatar
salimshah
25 Year Member
Dont expect much from OBDII code reader as they mostly cover emission.
Transmission check is important .. drain and examination of fluid + what ever comes out is important.
The auto trans has a feature where the fluid coupling is bypassed and you get direct connection with the engine at cruising speed. I assume you were on a flat road and no auto shifting was happening.
Salim
Old May 25, 2020 | 04:07 PM
G1RX300B's Avatar
G1RX300B
2009 Honda Silverwing. 14964 miles at time or purchase. Now, 15295.
No, I wasn't. I went to the (closed for the holiday) service center today. When I started the vehicle to drive it a quarter mile away (to see about having the codes checked), it immediately started with the "whirring" sounds. I just turned it off and went back home. I'll have the mechanic (hopefully) confirm the matter tomorrow.
Old May 25, 2020 | 04:12 PM
G1RX300B's Avatar
G1RX300B
Correct. Flat highway. Cruise set approx. 65mph.
nerv81
RX - 3rd Gen (2010-2015)
14
Jun 26, 2019 04:06 PM
otcviper
Sep 15, 2016 08:55 PM
engine89
20
Apr 13, 2013 08:30 PM
jtmarlin82
Feb 24, 2012 12:38 PM
marosekcmo
16
Sep 6, 2011 01:01 PM
