2000 lexus rx 300 transmission problems
Old Jul 13, 2020 | 07:16 PM
390ford's Avatar
390ford
Default 2000 lexus rx 300 transmission problems
The original transmission went bad so I dropped everything and installed a junk yard one. Everything looked good fluid was clean magnets had a lil stuff on them but nothing big. I put fluid in it what it called for on a dry system start the vehicle pull the stick its over full because its not pumping threw the system i pulled the lines and started it up no fluid coming from. The lines andine happen to know anything before I tear it back apart
Old Jul 13, 2020 | 07:45 PM
Worst case the pump was crushed due to improper installation of the torque converter. Did you use the bell housing bolts to force the transmission into the engine? If the TQ is not lined up correctly this will destroy the pump.
mrojas1700
Performance
Jul 17, 2017 09:44 AM
fancyjean
Dec 28, 2010 07:22 PM
uhohitzmik
Mar 18, 2009 01:45 PM
DKVL
Nov 19, 2008 08:25 AM
Vagus
Dec 14, 2004 02:51 AM
