- Looking to Get Back Into a IS350, but have a few questions....
- Bluetooth problem fixed!
- Steering Wheel Airbag Cover Logo
- 10 Amp fuse keeps blowing out after installing LED parking lights(HELP!)
- New VMR wheels on the Lexus
- New To CL: Show Me Your AWD in H&R's or Tire Setup with pics
- frontlip is250
- Connecting stock amp to channel
- Redline 6900 RPM TC off bad for engine?
- Im back!!!!
- center dash speaker
- Is CPO worth it on 2013 IS 250 AWD?
- Mix 'n Match Body kits -- help!
- battery replacement now tons of codes.
- Wheel & Tire Specs that fit H&R Springs
- Good riddance, 2011 IS250
- IS250 Frozen Navigation - Looking for someone to fix in SoCal
- Saw some fluid leak from battery
- IS250 AFS question
- Im somewhat excited
- Whats the name or part number?!
- Auto lock questions
- 2008 is250 power steering swap
- Would this work?
- Traction control off by default. Is this possible?
- Bigger factory rotors for is350?
- Tpms Module/ecu?
- changing my headlights and fogs
- Fuel Leak recall
- Drag rims from Discount Tire.
- Is250 A/C Help
- Farwell Lexus for now...
- Differential Service
- Trunk Adjustment?
- P0172 code to rich please help!
- Got battery tested at autozone
- Lexus is250 stalling rpm CEL on traction control and check vsc
- Next generation ISx LED tail lights from ebay
- Rancid smell @high speeds
- Quick Wheel fitment question
- Best affordable radar detector!?!?
- 2010 2IS A/C Loud Noise
- Best wheels to go with Tungsten Pearl IS???
- Lexus Dealership Fuel Injection Service
- IS350 Front-End Shivers - Idling at Stop Light
- VSC/TRAC CEL? MAF sensor help...
- Will These Wheels Fit
- 2012 Headlight from stock HID to LED bulbs?
- 3IS Style Tail Lights on 2IS
- 245/45vr18 on my is250?
- Just Picked Up A 2007 IS250, Couple Radio Questions
- IS250 2007 upgrade to 2010 navigation + LS600 19 mark levinson speakers
- Wedssport sa55m help!!!!!!
- gauge problems
- IS250 AWD wheel size/fitment
- Plastic dipped my fsport matte blue
- Eagle Eyes OEM style IS-F tails
- Thinking of Selling 2013 IS350 for Accord Hybrid 2015
- Poppin/static noise from speakers with car off
- Radio unit no power
- About 5k to replace power steering rack?
- Only 1 door unlocks. 10 beeps when unlocking
- Windshield replacement
- Purchasing 2012+ ISx50 Headlights
- IS250 2006' non-nav to 2009' facelift nav upgrade - J53 connector problem
- Aftermarket LED Projector headlight adjustment *help
- 2006 Lexus IS350 charging problems
- Recall - Fuel Gasket
- Nice looking steering wheels
- Touch screen doesn't work on Flyaudio
- Oil Gasket Recall
- 2006 is250 truck lid and hood
- ECU and the 1/4 Mile
- Help with rear bumper
- 2G IS350 - Best Bang for the Buck?
- Quick Question
- 2006 is350. does misfire and rough idle have anything to do with valve spring recall?
- New to Lexus
- Need help 2012 headlight on a 2009 is350
- anyone roll fenders at rms rolling and coating in fremont bay area
- 2008 is350 rotors replacing question
- "New" IS, minor issues?
- Xm satellite tuner install
- seeking bicycle carrier recommendation
- Check VSC light on IS350?
- Help on turning the airbag off airbag harness installed
- My IS250 is making me nauseous. Help!
- Black rectangle styrofoam in engine?
- Knock Sound at Low RPMS
- Gfx kit
- Meet Hunki and His Lexus IS Drift Missile
- Replace Headlight or Fix Tabs
- Oil Leak (pics) Help!
- Will a 3IS (2014) alternator work in a 2IS (2007) in spite of different part numbers?
- Unplugged Battery now check VSC
- Used Navi Unit or Specialty Repair Shop?
- Wife drove over a small pothole and the damage was $10,153. Lexus IS 250 please look
- How long does fuel pressure sensor recall take?
- Random question
- 2007 is250 headlight wiring issue
- Tough sell
- 2008 is250 ac issue
- Disappointed
- Turn signal relay
- Hello-can someone post the schematics to the
- Front and rear lip kits and side skirts
- Are the two pulleys the same?
- Error codes P2238 & P2241
- Speedometer/RPM needles not working.
- How Much $$ for an F Sport steering wheel? Anyone know what a good price is for one?
- 2007 IS250 RWD - rear links for Stabilizer Bar
- Aimgain spoiler
- my nav screen wont turn on
- Recall: On fuel leak ?
- How to replace CV shaft on my 2006 IS250?
- Parts help
- IS 250 AWD Axle (CV Halfshafts) - rear
- Where to buy side skirts
- Video! New style led tail lights
- Who's is250/350 is this?
- IS350 P0031 Code Help
- Custom VIP Interiors?
- IS 250 Oil leak
- 2014 3IS F-Sport Bumper Conversion
- 2011 IS 250 - Can the seat belt chime be disabled?
- difference in 4GR-FSE - '05-'10 vs '11>
- anyone rubbing with linea corse lc818??
- changing interior colos
- DRL Slim Decoder 06 IS350
- Metal polisher help.
- AC light
- 2009 is250 startup rattle
- intermittent vibrations
- Oil change every 5K miles or every 10K?
- Question Lowering AWD IS250 = Any lights on the dash???
- IS250 | IS350 Spec SSR TF1 in Titan Silver *BEAUTIFUL!
- sc300 200k miles
- Rear bumper metal tab shaving
- Need help with low offset rims!!
- Steering wheel question HELP!
- Photoshop this rims.
- Is this HID kit plug and play?
- Can anyone identify this front oem arm
- New Member, New to Lexus!
- how do I remove exhaust o2 sensors
- Pcv valve glad I changed!
- interior front door handel light mod
- Finally liking my Lexus..
- Back up camera - 2010 is350
- Keyless entry remote draining battery
- My new to me 2011 IS250 RWD 6MT W/ISF 19"wheels
- Lexus IS models Washer Fluid Leakage
- vertex rear lip in canada
- Stereo help please?
- Major roblem with Kuni Lexus
- Help please... Urgent.
- accident yesterday.... is this totaled
- anyone have these install? jdm fog light with led?
- Starting again:)
- Removing plasti dip, is thinner safe for the rim?
- S2k AP2 exhaust tip
- smog check question on IS350
- Aftermarket or retrofit headlight?
- carrier bushing/bearing
- How much bigger is the 350 chassis as opposed to the 250?
- First post! Slammed 2is
- 2006 IS205 Auto error code confusion
- DIY: Figs Engineering Front Lower Arm Rear Mount #2
- Brake Light Issues
- Rear Sway Swap--- ISF to Awd IS250
- Seeking Rim Opinions for my 2008 IS250 AWD
- Covert from Factory HID to aftermarket??
- Wiper Arm Identification
- Anyone install figs front lower rear mount #2???
- Continuously warping rotors!?
- Caliper color for DSM
- From Factory HIDs to Aftermarket HIDs????
- Hitting Rev limiter in Auto mode.
- changing gear ratios
- HID or halogen Bulb
- My First Post - Is it Worth Waiting??
- Navigation unit color code
- The tire stretch comparison thread
- Driver Rearview Mirror
- does AWD aftermarket shocks come with front C clamps attached?
- Torn between the IS and GS.
- Which exhaust gasket is the toward the front of car, biginning of pipe?
- How Much Do You Pay for Oil Change?
- Dash lighting
- Any Lexus engineers here? (cutting & welding gear selector to shorten it)
- Video input non ML nav system
- 09 IS 250 only starts when it's sunny
- Kazz with black vinyl surround?
- Help me diagnose this annoying sound!!
- 2009-10 bumper on 2008
- LEXUS RC350 F wheels on my IS350??
- Interior Panel?
- Axle-back Exhaust Leak?
- Pet seat cover recomendations
- My opinion on the G37
- how many resonators does a is350 have?
- FS and WTB threads go in the classifieds
- Slight Vibrations at HWY speeds
- EBay 2012 Headlight Upgrade??
- 2011-2013 is350 pros and cons
- New car shopping, need advise
- In need of some fast help!!
- how many cats does a 2006 is350 have?
- Is350 in the making
- Saw RC350 on the Road for the First Time, Not Impressed
- Getting a Lexus IS350, first car (maybe second)
- Black chrome grille surround?
- Roof rack options
- Slight Vibration on Coasting
- Rear Tire Mud Flap/Plastic Piece
- Popping noise on bumps
- Buying a Lexus IS250 100k+ miles. Opinions?
- chirping coming from glove box
- is this a decent deal on a is350?
- Engine Mounts needed - advice welcomed
- Fsport replica grill installed
- How can people afford all their mods?
- 2007 IS350 SGM Engine Cleaning/Tune
- Need Help With GFX Side Skirts
- Rattling/Grinding noise when car is on
- LMS intake in CA/smog test
- Lexus or Toyota for Service?
- Headlight Issue Please Help!
- Corrosion question
- Seeking source for exhaust gaskets and related
- 2011 is350F Seat Height/Headroom - Lowering Brackets?
- Bought a Used 2008 IS 350
- Suspension issues updated pictures.
- 1g1 paint code members please help
- is this a decent deal on 07 is250?
- Navigation System stuck
- check engine problem
- DAI Autobahn Wheels Tight Fit
- Camber Tire Wear
- Root beer brown Aimgain IS!!!!
- HID/AFS Help...
- bad Experience with L tuned parts
- Appraisal value for 06 is350
- Weeird noise coming from engine after its off
- New to Lexus Maybe IS350 AWD
- Timing Cover Leak, Gurus and Techs Please Chime in
- oil?
- Suspension still Messed
- Rear GFX lip install
- Will these LEDs fit as a trunk light replacement?
