- ERR3 Code on CD Player
- Navigation System Display And All Funtion Sourounding Side Buttons Of Disply
- Pioneer or Nakamichi in our cars??
- Rockford Fosgate!!!!!!!!
- 91 LS400 remote start
- custom enclosure ?????
- Location of Vehicle Speed sensor on 00 GS400??
- Are There Transponder Chips In A 95 Sc Key?
- cd changer 97 es
- Occasional radio problem - 90' LS400
- GS polarity
- 92 Sc400 Aftermarket Amp
- Lx470 Amp Location
- CD-Rs....
- Quick fix or no ? Door / Alarm problem
- programming a key on a 92 sc300
- Front Speakers Cut off with Bass Peaks?
- CDs stuck in Dash
- CDs stuck in dash
- kenwood 7015
- Installing Toyota navigation in SC
- Went outside 10 min ago and car was running
- Subs in a SC400
- Subs in a SC400
- FM modulation question (sirius satelite)
- the speaker amp question..
- Before I spend money getting this installed...
- CD Changer not working...any help??
- Lights in the buttons of the head unit and AC controls
- Electrical Ground problems....Still!
- Stereo Changing Channels on its own?
- 2004 IS300 In-Dash Monitor
- subs
- Suggestion on Headrest Monitor
- Replacing Pioneer speakers with Nakamichi speakers?
- SC Premium F/R Speaker Frequency Response
- dvd nav questions
- FOUND A PLACE that sells NAK 98 +GS'
- question re removing GS tweeter
- Aftermarket Headunit 92 SC400
- 49MPG Current Fuel Consumption Reading on a 99LS400
- 99 LS400 with Bad radio LCD
- xm satellite for the ls
- JBL/Crown Amps?
- Radio fuse
- Suggestions for replacing door speakers
- BEst sounding connection? (use LLC-RCA or not?)
- Rattling noise from sub?
- CD Changer
- rear fill speakers?
- help with remote wire for amp on the stock deck
- My sound system
- sound system almost done..................
- Quick question regarding removing door panels on GS
- Help me pick my headunit!
- Stereo wiring harness- 99 gs3?
- NAV,dvd, mp3, radio, tv, etc...
- Changing Out the Stock Speakers IS 300
- GS amp schematics
- Sirius Question ... Service Related
- Stock sub upgrade DONE!
- Valentine One question for SC owners
- Sound Deadening Overview.
- ipod and in-indash dvd in a ls430
- *** Eclipse products ***
- Speaker upgrade on 98 GS?
- Help me choose a system
- recommend installer in NC?
- DVD monitors
- Pros and/or cons of same amp & speaker company
- Navigation Swap Question...NAv into a GS400 without NAV
- Diaging ES300 Stereo
- Krylon Fusion...
- sc300 and 400 guys
- Changing the factory changer...
- LLC? Is It A IEC AULOC Line Output Converter?
- Alarm
- jl audio W6 vs Free air
- more bass in SC430 w/out altering stock ML system
- Spark from negative battery cable
- Help! I'm getting zero volume from my stock radio!
- What size amp?
- Demo Vehicle Finally Finished!
- CVA-1004 and CHA-1214
- LS400 Stereo Dash Kit
- Instructions for speaker install in 4Runner?
- Did i mess up my Alpine unit?
- Whats the best place to ground my "Subwoofer Amplifier" in my trunk?
- 1999 GS300 Cd Player
- High resolution LCD monitor
- CD player installed with WORKING antenna
- Stock HU w/ Aftermarket amp+Sub
- Good TV tuner and antenna
- Treo 600 Phone
- Speaker upgrade?
- help please on radio install (pleaseeee)
- having a tough time deciding, could you guys help me out?
- No power to fuse box
- "Diagnostic" light turned red
- indash tv/radio install for gs400
- gs300 audio wiring???
- New speakers....now it REALLY sounds like crap
- gs300 wiring diagram HELP
- Where do you buy all your car audio gear?
- After Market Amp
- Lost my radio reception after dynamat??
- Please help!! Lexus ES 300 '92 w/ audio system problems
- 15" brahma sub with vented enclosure
- installin pioneer deh-p6400n head unit
- HELP! Need to install 6.5 in front doors Y2K GS4 (CDT HD)
- Plan to put indash monitor in my 92 SC 400
- 1990 ls400 sealed subwoofer install
- Weird behavior when disabling speed sensor to nav system
- Sc300 Head Unit Install Question
- Who does make Navigation system for Lexus?
- AHHH! yet another antenna problem...
- Master remote key: can new blank be cut for remote??
- Turning DVD on w/out the remote
- Pioneer 4" TS-G1040R speakers for SC400
- Parking Brake Detection Switch
- metra dash kit and radio harness adapter
- remote turn on
- Monitor interference and headphone buzz help needed
- For those who dont want to go JL for free air....
- need pic of inside of single button transponder key...
- is300 install
- Geek my Ride!!
- TV/DVD on ES330 Navigation screen
- What's going on w/my car stereo?
- line level to RCA converter causing distortion?
- early 90's LS400 Subwoofer fit a 93 SC 400 and mount up?
- Removal of stock HU?
- Nav Logo Screen
- GS430 XM Commander & NAVTV install
- Can someone post diagram of kick panel fuse box?
- Radio Automatic Sound Level
- blew my fuses, now can't find the one i blew.
- What should I tap into??
- Factory head unit w/aftermarket amp and subs
- Schemetic to make GEX-P7000TV to work
- Cd Player Stops Playing When Steping On The Brakes
- Anyone using CDT HD-62 on their GS4?
- LS400 glove box cd changer
- LS400 cd changer
- Free air sub can damage rear window?
- Best components for under $400
- How is this possible (sc400 audio)
- WTB, need, a 90-93 LS cd changer HELP!!
- Subs in Parallel....Help.
- Need Help Installing Amp & Sub In my GS 300
- neeed help with sc400 deck installation
- Crazy Windows. Help. Car Upset.
- swapping disc changers?
- iPod hook up?
- Proper amp for my JL 10IB4 ?
- replace just two or all at once???
- Ground Wire problem
- CD reciever INFO
- AVIC-N1 speed sensor install?
- Door panel removal?
- Parents' Lexus ls 400 1996
- '96 Radio help...
- I need to be certain about 6.5 speakers!
- Kenwood Indash Tv
- CDT Audio CL-61a + oem?
- no sound coming from my speakers
- Installation ????
- what size tweeter to replace stock ones? GS4
- es300 speaker install writeup?
- Speaker Install - "How-To" with TONS of pics!! LS400
- Alpine, Anyone?
- adding aftermarket sub and amp......
- Installing a sub, colors of rear speaker wires??
- Up-dating the sound system
- amp & sub
- Front Speakers Just Blew Out!
- Anyone Have '99 Elec. Diagrams? (Rear View Mirrors)
- How many gb is the Navigation HDD?
- Bypassing stock tape unit for navigation??
- That damn black wire!!!
- I need a straight answer for the JL 10IB4 sub
- Completely Redoing Sound System
- ALPINE NAVIGATION question
- whats better ALPINE or PIONEER or OTHER?
- Advice? Did my gs300 get a fair sub+amp install on my Mark Levinson?
- Anyone with an aftermarket deck for 02+ ES?
- Good setup for my GS 300?
- amp hook up
- How do I program the remote button on my 2000 RX for a security gate?
- Wire Problems
- Black wire prob??
- Running wires behind glove box
- Need Help! How to install aftermarket radio in LS400?
- What aftermarket free air sub will fit in oem locaton
- Has anyone moved the battery to the trunk?
- speakers
- 97 lx 450 stereo trouble
- fiberglassing!!
- es300 stereo question
- need old speakers for experimentation
- 93 LS, completed system w/ pics!
- best speakers
- equalizer behind the cd changer on my 98 gs400
- Price check on subwoofer
- Remote entry
- Bad info -- this can't be right
- 01 LS430 Mark Levinson no sound help!!!
- LS400 sub
- New cloth speaker covers?
- range of key
- directions to program a new key
- Need help with sub install in SC400
- Two problems: Little help please
- Anyone running 6.5" in the front?
- Battery "Perspiring" slightly
- Where I can find the wire harness 4 my 98 GS400 w/Nak ??
- Static in AM stations
- Need Help! ES300 Subwoofer
- Static/Crackling Sound Coming From Free-Air Sub.
- Please, help me! My Car-audio LCD-display donīt work
- 1992 SC300 head unit wiring?
- Amplifier Location
- USA Spec CD Changer Instead of Pioneer OEM. Is this possible?
- New radio
- Dash Warning Lights
- Wondering about some simple audio upgrades for my SC
- 93 LS, 5.25" speaker install...bit off WAY more than I can chew!
- Laptop w/ GPS Navigation in car.
- Polk momo?
- Plug & Play with touch screen XM radio on GS430 with Nav.
- Relatively inexpensive upgrade for stock GS400 stereo
- Strange radio problem with Soarer SC430
- Nav system in a '97 SC300
- Aftermarket HU with stock amp
- 5.1 in car or no??
- Help Q? source switcher
- BATTERY: Optima Yellow Top + Stock?
- subwoofer size ?
- i had an idea for my sound system
- Headrest monitor and Xbox question
- windows : computer in car
- subwoofer volume
- SC430 "NO DISK" message
- Help-Sound problem on 95 LS400 w/Nak.
- 2 amps or 1??
- drive soft
- Aftermarket amp to SC nak system?
- installing alarm on SC400
- LX-470 DVD Nav Unit
- 1998 SC 400 - CD/MP3 Player
