- SC400 Alarm Wiring
- ES300 - changing only speakers, is it worth it?
- Need quility reasonably priced sound system installer/shop NY/NJ area!!
- Using stock head unit on 01 GS430 for new System!!
- Anyone running navi/ML with aftermarket amp?
- sub only works when braking...
- Experience with CD-Rs in factory cd changers
- Any 6 disc changer with mp3?
- Keyless door open doesnt work 92sc300
- Lexus Key Battery?
- Is this possible to do?
- New system
- HU plays memory cards?
- Can I replace my powered antenna with a short non-powered one?
- Disable factory alarm for '91 LS400
- Replacing Factory Sub
- 95 LS400 Speed Sensor VSS and Kenwood Navigation Question
- hey guys,.,. static,
- Help with my Audio!!!
- Kenwood Nav Install need help 00gs3
- Need A set up
- Pioneer Head Unit and Stock CD Changer
- Carputers?
- Another weird CD changer problem...
- ES Security
- After an exhaustive search, I have decided on Kenwood for NAV
- head units 98 GS 300
- BassLink Overpowering Stock Sub
- Aftermarket GPS for GS300
- Rear speakers/sub dont seem to work
- Bin Replacement
- Best SUB installation for GS430 for best SQ, Help!
- Best sub placement in GS430, help?
- New key/ecu question
- 1992 upgrade to 2002
- ICE Upgrade Time
- who can build me this ???
- ignition key cylinder removal
- Speakers die when it rains. HELP!
- i hate my fatory cd player !?!?!
- 1997 SC400 keyless entry beep
- Light on dash after stereo fix
- Climate control fuse blown
- Did anyone do Infinite Baffle/Free-AIr Sub Application on rear deck on GS?
- Pioneer AVIC-N1 Install help
- Installing an Alpine IVA-D900 on an SC300
- Are 10W0 JL's Good Speakers or 10W3D6 10"?
- Lights Dimming?
- sc key wont work for glove box and trunk lock!
- SC400 amp install confusion -HELP!
- Stereo problems-humming noise/ what amp-sub
- SC400 Pioneer non-cd to Nakamichi
- Grinding Antenna Mast
- few pictures of my audio progress
- So Alpine or Pioneer Electronics. Full NAV and what not
- When is it time to upgrade security?
- SC400 Volume Problem
- What 2 use for rubber spinners...Need answer quick!
- show off your music
- Jerry do i need one of these ??
- Aftermarket deck install question about factory amp
- infinite baffle (free air) subs... do they need to be sealed on the back side?
- Gauge Cluster is OUT - Electrical Problem after Stereo Install
- 1993 Lexus ES300 factory amp bypass
- Dynaudio Contour SC Center and T 21
- ? about sirius radio
- Opinions on this future setup?
- Navigation Information On gs300
- Stereo manufacturer??
- adding xtra cd changer to GS430
- NAV retrofit installation question
- Different Alternatve for 6-disk
- how to take the ML system to the next level
- Interference from cell phones
- CD Player Question...
- Pioneer avic-d1, the answer for the SC???
- installing an mp3 player into my GS questions
- What should i get for a system?
- Has anybody ran a system with the stock head unit?
- Why is my dash smoking?!?!
- My SC Tweeter Mod
- GS4 w/NAV - Replace stereo only?
- RX300 Audio help
- i think im going to go for it ..GS owners let me see your systems
- 1997 SC Audio ?
- 1990 ls 400 : running wiring for amp/sub ??
- Installing a subwoofer
- 12CD changer and Burned CDs
- Alpine Dvd In-dash Help!! D300, D310, D900, D901
- factory dvd player in gs430
- 6.5 Componets in Front 2nd LS
- 98 GS300:Need diagram from service manual
- Ml Sub Woofer Stopped Working
- Lexus SmartAccess Upgrade??
- Upgrading from Nakamichi system in SC300
- Quick Questions on System install!?
- GURUs Help! GS400 quick question? Polk DB6750..
- Stereo install question - Need help
- Help with speakers
- how do u configure JL amps
- Whats the spec on ES300 97 speakers?
- locked stereo
- Indash DVD player with monitor. recommendations
- CD changer wire touched chasis..stereo out..help?
- Navigation System DVD
- Great links to other Car Audio resources!
- IN-DASH DVD player with detachable face
- Repair Lights in Head Unit or ????
- Installed System Now Bad Reception?
- Awesome Active LLC with other goodies
- question .....
- Need some direction
- Installed 6.5 Componets in rear door of LS
- Where is my amp located?
- Car audio forums
- 2001 GS430 Mark Levinson Speaker Upgrade
- 2 of my alarm button doesnt work
- Alarm system install
- Pioneer D1 and N1 questions
- SIRIUS Satellite Radio Now Available in Toyota and Scion Vehicles
- is this possible?
- Xtant Amps in a SC300?
- Sub Amp Hook up Problem HELP !
- Amp getting really hot, speakers fuzzy
- Infinity Basslink Location
- aftermarket cd changers
- Upgrading Speakers and Sub in GS430, any suggestions with what?
- Thinking about a Basslink
- power ANTENNA delete!! anyone done it?? HELP
- what do you guys recommend for a flush mount screen?
- GS430 Sound System Upgrade Help!!!
- Different backlight colors for HU on SC's?!?
- CD changer
- SC's Dont like aftermakert HU
- can't turn music up on mark levinson syst
- Aftermarket HU for SC300
- Remote start/tilt steering HELP!
- who makes the best in-dash tv screens?
- And So...... It Begins!
- ??? w/ a new system in '01 GS430
- RX 300 cd changer install?
- Stereo Installation Kit
- navigation options
- SC 430 + dvd video?
- 96 Es 300 Radio LCD
- LS400 Rear speakers
- GS Speaker, Amp,door removal Questions?
- MB Quart speakers?
- Difference between sc400 Nakamichi amps?
- Anyone with an S-AFC?
- FINALLY did the Optima Yellow Top upgrade
- What kind of amp to power 12w3?
- sprint audiovox ppc-6600 and phonebook
- Air Condition heater blower not turning on
- 1992 SC300, factory alarm not responding...
- 95 ES LLC Question
- Sc400 Raido
- Hidden sub box in SC400
- 03 gs 300 wiring harness?
- Weak aftermarket speakers
- My Nakamichi Sound System - Phooey!
- Decent AMP with speaker inputs?
- Piping behind stock double din radio
- Speaker Size Gs430
- atten: pro sounds on cicero/chicago! important
- sc 12disk cd changer problems
- GS Door speakers w/o amp upgrade
- single vs. dual
- How powerful is the stock subwoofer amp?
- What Alarm System Do You Recommend?
- question on installin new aftermarket HU
- subs in a 93
- Headunit Install Messed Up The Power Door Locks
- Antenna Mast Installation
- Opinions on the AlumaPro Alchemy MX12 subwoofer?
- Cant Decide!!
- Need a lil help...
- Rockford Fosgate
- Oh No!!!
- Nakimichi Amp Repair
- Interference on Nav Screen
- i need subs for my 93
- S-AFC and S-AFC2 difference?
- Need help to choose the right CD changer
- My Check Engine light turned on after alarm install
- tweeters okay in rear door?
- free air vs. enclosed subs?
- Aftermarket Car Audio Stuff for rhe SC
- plastic structure to support amps
- '01 IS300 - Audio Questions
- sc sound system
- Spare or No Spare?
- Lexus Navigation or aftermarket navi ?
- Infinity 12" sub?
- Any info on the release date of the new Eclipse AVN5495??
- 93 ES300 Wire harness question..
- Are SC oem stereo's interchangeable?
- Just got back from driving inSpain, anyone know of a GPS system that would work there
- Cd install kit SC300/400 (Already searched/FAQ)
- 1990 wierd stereo setup question
- Need a replacement ML tweeter for rear door
- Code Alarm
- GS to SC stock speakers compatible?
- Stereo Whine That Shouldnt Be There
- Norm susp light flashing on Gen 1 with elect susp
- 94 LS400 changer options
- system suggestions for a gs
- Sound system
- wutch think bout the eclipse avx units
- door speaker upgrade
- Optima Battery Hold-Down
- Upgrading Door Speaker ???'s
- Sponsorship: is this for me?
- Will GS400 Nak. System fit SC400?
- Freeair and enclosed subs
- Can I add a amp to factory system?
- Problem with windshield wipers
- Kenwood KVT
- Upgrading to Nak system question
- Lexus DVD/NAV Converter system
- Hey (I hear a high pitched noise that gets higher pitched and louder everytime )
- Phonebook data transfer w/o phone?
- can anyone help me?
- a fix for some stock cd changer problems
- what kind of wire for amp install????
- need help with wires from nakamichi unit
- power antenna...HATE it.....any way to DELETE it??
- Cutting some of the trunk to install subs
- Where to mount S-AFC and TV in SC?
- DVD update 4.1 won't work
- Low tweeter output 94 LS400 Nakamichi
- Keyless Entry
- Will this setup work in my SC300???
- 2-DIN to 2.5-DIN Conversion with Four.1 Modification
- Uneven sound from left and right speakers?
- Is this the stock alarm
- almost zero bass after Premier install
- Alumapro Alchemy Free-Air
- RX300 - 6 CD changer stuck!
- Looking for feedback on Eclipse subs
- 99+ GS3/4 wire diagrahm
- 12 disc changer info
- SC300/400 Best route to better sound, skip Nak?
- AC and Stereo System questions
- Ok, complete new sound system idea (overall schematic paint image for my 90 LS)
- PPI vs JL..help
- 6x9 in front doors + amp hookup from factory headunit
- Blown ML Sub 2001
- SAFC-2 bracket
