Key will not come out
Old May 21, 2009 | 12:47 PM
cbc's lex's Avatar
cbc's lex
Angry Key will not come out
My key is stuck in my ignition and I also have something under my shifter making a clicking noise when I press the brake. I was told neutral safety switch, so I replaced it and still no... My guess is whatever is making the clicking noise is bad and therefore telling my car not to release the key. I would very greatly appreciate some input.
Old May 21, 2009 | 02:03 PM
BigGreen's Avatar
BigGreen
I believe that the clicking noise that you are hearing is normal and is the sound of the release letting go to be able to switch gears. I had a similar problem but I was able to remove my key but my engine would not shut off, they said it was my starter. It could possible be that your key got hot and might have melted
Old May 21, 2009 | 04:55 PM
cbc's lex's Avatar
cbc's lex
That's not it because the key will come out after about half an our of the car being shut off. And it never used to make the clicking noise before. All the fuses are good too.
Old May 21, 2009 | 05:01 PM
hentaro's Avatar
hentaro
Maybe check if you're in park all the way. Sometimes things get stuck in between the gap of park and the end. If there's something in the way then the key wont be able to turn to the far left position.
djrazr
Jan 15, 2012 09:41 PM
BrittonJ85
Apr 21, 2011 06:45 AM
3dog
Dec 27, 2004 02:17 AM
Ken98LS400
Aug 20, 2003 09:55 PM
