Air Bag light on!
Old May 20, 2009 | 10:19 PM
logicalman's Avatar
logicalman
Default Air Bag light on!
my airbag light is flashing code 14 and 54 can somebody tell me what it means?
Old May 20, 2009 | 10:33 PM
vinh's Avatar
vinh
Did you turn the car on at all when the airbag was not connected? Something small like that could set the light off.
Just take the bulb out. It's what i did.
Old May 20, 2009 | 10:41 PM
TheMole's Avatar
TheMole
Did you disconnect both battery terminals when you removed the airbags?
Old May 21, 2009 | 12:28 PM
logicalman's Avatar
logicalman
i dont really wanna just take out the bulb if there is something like resetting the air bag computer/relay or fuse. i did turn the car on while the air bags were out.
yes, i did disconnect both battery terminals when i removed the airbags but again i turned the car on while they were out.
is there a fuse/relay or something to reset it?
Old May 21, 2009 | 12:35 PM
2turbo1sup's Avatar
2turbo1sup
reset it. if you mess with anything that has to do with it (taking the cluster out, unplugging wires, etc) it will set it off.
Old May 23, 2009 | 09:48 AM
logicalman's Avatar
logicalman
thats what i was asking, is there a fuse/relay i can pull to reset it? i've already disconnected the battery and the light is still on.
Old May 23, 2009 | 12:28 PM
Enigma8246's Avatar
Enigma8246
https://www.clublexus.com/forums/sc-...ght-reset.html
Old May 24, 2009 | 12:53 PM
logicalman's Avatar
logicalman
thanks mang!
Old Jul 3, 2009 | 02:08 PM
logicalman's Avatar
logicalman
help me please!
Old Jul 3, 2009 | 02:56 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
You serious?! Its all there. Plug the airbags back in and then reset the light.
Old Jul 5, 2009 | 10:04 AM
logicalman's Avatar
logicalman
i plugged all the bags back in and my light doesnt blink code 22. i tried resetting it and it didnt work so yes im very serious.
Old Jul 5, 2009 | 10:23 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
you must do the wire dance to ground. it takes like 50 tries to reset it sometimes. its ridiculous. Ive gotten pretty good at it and it is still hard.
pulling the bulb out is silly because you get rid of the light, but then your airbags may not deploy...
Old Jul 7, 2009 | 03:16 PM
logicalman's Avatar
logicalman
imma try the wire dance 50 more times hopefully i get it thanks.
RWC SC400
Jan 6, 2021 06:53 PM
Dame9
Dec 27, 2017 04:39 PM
Jeanb
May 4, 2011 12:17 AM
no2faber
Aug 17, 2006 09:43 AM
Ferdi
May 10, 2002 01:50 AM
