Not sure if I should replace the rear strut mounts?
So I finally got around to changing the struts on my SC............needless to say after 180k the OEM struts were toast as were the Bump stops. The left front stop was in pieces LITERALLY and the right one was in half, but to my surprise the mounts were fine. I thought the SC had bearing in the mounts, but they dont, all they have is a rubber grommet that helps hold the spring insulator in place. I had already purchased new front mounts from rockauto so I put those on but I really didnt need to waste the $40 for them.
Now I still need to replace my rears and I'm wondering if I should buy new mounts seeing how the fronts were perfectly fine? For those of you who replaced the struts on the SC did you reuse the mounts and just change out the stops and boots? Normally I would just purchase new mounts but I would rather put the $100+ for the mounts toward either LCA's, Tire Rods, PS Pump, Gasket Kit and the list goes on lol. The other issue is not a single place around here stocks them and every shop has to order em and it is going to take atleast a week to arrive..................I'm not patience once I start something lol.
RyanV
Dec 11, 2009 08:47 AM
mrekid
RX - 1st Gen (1999-2003)
Nov 20, 2006 10:48 AM
