Loud Rear Wheel
Loud Rear Wheel
Have 2006 RX330 FWD Its to have a lot of noise (left rear)at highway speeds. All tires are new, less than 8K on them . Do not here the other tires makes a lot of noise at highway speed. My guess is a wheel hub. Is this a common problem on RX330? And how can to check it before you replace it THANKS donmck1950@aol.com
since you have a FWD, you are in luck.
jack up the rear of the vehicle, and spin the rear wheels by hand, and compare the noise/ vibration.
thats your suspect.
other option is to just replace both, they are 100 bucks each at rockauto
thats your suspect.
Does the pitch of the noise change when you drive from asphalt to concrete? If not you have a bad wheel bearing.
This helps if you end up jacking up although it will be tough to get any speed on the wheels.
It is not a common problem but they do go bad once in a while for some people.
Might be the tire. Have a 2002 RX300 that had a 'thrumming' sound in right rear.
Tire tread was lower on one side of tire, but tire balanced perfectly.
Name brand tire. Was surprised. Just lived w/the noise for a while until it was time to replace all four.
