Are There Replaceable Batteries in the 2007 RX350 Tire Pressure Monitors?
Soon I will be having our local Lexus dealer put on a new set of tires (purchased independently by me) on our 2007 RX350 (which we've owned since new). So the question is whether there are replaceable batteries in each sensors since I'd rather replace them now rather than after the new tires are mounted. As an aside, we only drive this car about 5,000 miles a year, so this will probably be our last set of tires.
The Lexus (and most OEM) sensors are ridiculously expensive. However, there is a company (Titan - I believe the website is Titantmps.com - or google it) who sells sensors they say are equivalent to OEM at quite good prices, relatively speaking. There is also the matter of 'coding' the received in the vehicle to the new sensors, which is required.
Good luck!
They have batteries, but the batteries are sesled into the sensor and cannot be replaced. The entire TMPS sensors need to be replaced. I too installed new tires on a 2009RX (built mid-2008) and I asked a Lexus tech whether I should replace the TMPS preventively. He advised against it, saying that they lasted a lot more than people thought and that they had had very few that needed replacement. Elsewhere, I read - but cannot guarantee accuracy - that the sensors 'sleep' when the wheels don't turn, so they may well last longer when fewer annual miles are driven as compared to more annual miles driven. But - who really knows? I decided to take a chance and did not change the TMPS sensors.
Good luck!
Good luck!
The monitor in the car is 'alerted' when it doesn't get the signal that the tires are sufficiently inflated. Without a battery, the sensor does not send the signal.
Yup no battery no signal. My daughter is running around with two bad sensors. Lexus didn't make it easy to diagnose unless you have the diagnostic tool, GM however has a system where you rotate from each tire and the system beeps at you if it is working.
Thanks all for you comments. As an aside the Club Lexus price for an OEM TPMS at Sewell is $59.88. Their description for this sensor says the battery has a "lifespan of approximately 10 years."
Good luck!
Good luck!
Would the owners of all 2nd generation RX 2007 and older please chime in as to whether you have had to replace a tire pressure sensor. I'm still debating whether to replace them when I put on new tires on my 2007, Getting some group experience would be helpful for all of us. Thanks in advance!
We owned a 2004 Acura MDX, and the original TPMS sensors still worked after 11 years.
All 2nd gen's should have a full sized spare on a factory aluminum wheel ........ my Lexus dealer stated that the spare tire is also monitored. It would make sense that the full sized factory aluminum wheel spare has a TPMS sensor. I have read the owners manually (not cover to cover) but have not seen any mention of how the TPMS system works with the spare.
Now I am curious enough about the spare to do a test ......... I can put the spare in the cargo area, decrease the air pressure and drive around to see if the TPMS light triggers. If it does, and I am confident that the spinning wheels are good, then I guess I have validated that the system monitors the spare. If it does monitor the spare, that is a nice touch, because you do not want your spare to be flat when you need it.
There are various iterations of TPMS systems and I suspect that the systems that do the minimum are done that way for cost reduction. Our company president has an LS460 and it shows the actual pressure of each wheel, which is nice as it removes the guess work about which tire needs air.
If your spare has a metal valve stem then it has a sensor. Most lexus's that have a full size spare usually do. After 5 years or 80k miles the batteries are more likely to die. Also, if you have ever ran a tire low and triggered the light on your dashboard then that sensor is probably going to be the first to go out. The dealer may be able to run a test on the sensors to tell you if they are near the end of their life, but not all sensors and tools show battery life. If you choose not to replace the sensors you should replace their Service kit. (valve core, rubber grommet and locking nut)
