- Just my luck....Aaargh
- Sparco seina seats supra rails
- DRL for 97 model and Down
- LED bulbs for our cars
- Amp Replacement Question
- SC400 Lug nut Torque
- SC 1st Gen vs SC 2nd Gen
- code 12 after rx steering swap
- Flat towing an SC using a tow-bar
- Has anyone seen a sc painted Austin yellow?
- Front White Line Sway Bar (End Links)
- Gauge cluster random question
- OG member with a Soarer inbound!
- Question about sub
- Switch to led taillight bulbs, turn signals won't flash.
- New to the forums, help!
- All FS & WTB go in classifieds section only
- Work wheel questions...
- SC300/SC400 OEM Subwoofer Question
- Headlights
- Collection of parts...
- Seats with release lever at shoulder
- 98 SC400 seats in a 92 SC400...
- Rear bumper lip differences?
- 97 sc300 rack polyurethane bushing grease help
- Damn Blinkers...anyone have a fix?
- Where's all the sc400 99" I got mine
- Transport 4 17inch wheels with tires inside sc
- CD magazine stuck in changer
- 1991 Soarer UZZ32 Limited
- Are all year SC seatbelts compatible?
- looking for pictures of sc on 19in wheels only
- Photo Shoot 2016!
- Wtb and FS go only in the classifieds
- Is there a body wiring pinout somewhere?
- My 93sc300( siren ) pausing when accelerating
- Anyone else making Carbon fiber
- Help Finding Combo Lamp Part
- Driver side Heated seat not working
- Maverick Steering Rack Spacers for Sc300
- Towing the SC
- Build an SC with limitless compatibility issues
- New guy with a 1993 SC400
- 92 sc400 ITB requirements
- What Would YOU do?/ Where would you go from here?
- wire harness relocation issue
- My car got hit, while parked, AGAIN!!!
- lost the master key
- Looking for somewhere that has the Blitz Nur in stock.
- 1991 Toyota Soarer Limited V8 - Radio & Alarm System
- Easy aftermarket stereo reciever
- rethinking the dash vents
- Hello! Cloth seats/slick top/5spd 93
- How to ship carpet and door panels
- 2000 seats in a 97 not all functions work now?
- Removal of instrument cluster
- What is that Rectangular Foam Covered Item with the Radio Harness?
- Front bumper holes pushed in towards car?
- aftermarket steering wheel hub
- I broke the harness that connects to the master lock/window control
- What part typically bends?
- Removal of sunroof?
- FS threads go in the classifieds only
- Squeaky noise!
- Who moved their SC300 badge?
- Does carbon fiber clash w/ dark wood grain?
- Lexus SC400 Carbon Fiber
- 1991 Toyota Soarer GT (Questions)
- Side skirt add on?
- '98 seat back board
- Low beam problems.
- 92 SC400 on the "bay for $26,450
- Sunroof glass cost that much?!?!
- Are aluminum lug nuts safe?
- Rear Deck DIY Question
- Need help identifying something to complete window regulator/motor
- who makes this hood?
- You Don't See a Lexus SC300 With a 5-Speed Very Often
- New Stereo, Sub not working
- LED rear running lights
- Lighting
- 97 5Spd for $7500 worth it?
- Security beeper
- Where Can I get this?
- 92 sc300
- Soarer experts and those in the know, need production statistics answer
- Water in floorboard
- back from the dead
- Weird Clock/cluster issue
- Can You Bypass Heater Core
- I think I post too many threads (and am starting to worry about my new SC)
- Turbo Timer Install questions
- Question: SC400 Stock ride specs
- sc400 lsd
- wood trim refinishing
- cleaned up the stock cd changer wiring now cluster doesn't light up
- 97' SC300 - 19" SSR Professor's (color matched DWP)
- 520,000+ mile 97 Supra NA on original engine
- SC400 steering column problem
- Parts Guy Problems - Am I Being A Whiner?
- Rare 1992 "Lexus Coupe" (SC) TV commercial
- DDM fogs went out, suggestions?
- Window regulator modifications
- Shifting questions for 5-speed SC300 owners
- 1998 SC400 - ECU Repair Recommendations
- 95 SC400 fog light keeps filling with water
- Value of 1996 Sc300
- Strength in numbers (looking for member in Cincinnati, Ohio area to look at a SC)
- Its a sad day men.
- Fiberglass door panels
- 2jzgte vvti swap NEED HELP!
- 19s +12 et clear pulled rear fenders?
- How to fix this seat???
- A couple of options
- Is it really that hard not to hit my parked car???
- 93 sc300 electrical issue
- Stupid cluster is dimming when I hit the brakes
- 1994 SC300 exhaust fumes in car
- Lexus Owner's Manual pen refills
- W58 info needed
- Key stuck in ignition on acc & stuck in park
- Is it important
- Wooden Shift Knob Before My 5 Speed SC300 Turns 20 Years Younger!
- SC 300 gas mileage tips
- these floor mats fit the sc!
- 1993 Lexus SC400 power seat problem!
- Noob move.
- Potential buyer needs input on near-mint 5spd SC300!
- Safety Switch?
- Damn I need help (putting descriptive titles on my thread)
- SC300/400 High Beam Retrofit DIY
- backup camera wiring
- How to FIX/paint door module
- Terrible cabin odor
- SC400 Driver's Window Glass Removal
- 1uzfe swap, can't pull codes:(, Help please!!
- Got rolled on by a Toyota Matrix the other day...
- Jalopnik article mentioning the SC300, GS300, and IS300 as MKIV alternatives
- re: Aem v1 lq9 coil set-up
- 6sp tt pumpkin into sc300
- LH Window Glass Fitment
- Cassette won't load on to track
- 1997 sc300 out for the spring
- Ac light still blinking after replacing relay sensor
- CEL comming on at a odd time
- P/N for Passenger Window Mechanism
- SC Parts for sale go in the classifieds, not here
- New SC owner
- Pics From WekFest Chicago 2016
- Which color wheels?
- signal lights
- Install Moldings After Skirts?
- Help!! Stereo, A/C problem
- Improving radio reception, broken antenna . . . .
- '92 to '97 versus '98 to '00 OEM strut/insulator/bump stops
- Help with steering wheel please..
- SEM interior painting steps?
- Sad day, crunched in parking garage at work
- 2jzge has a coolant leak
- Wiring Harness Repair Questions
- Lexus SC Info needed
- What CF parts you want (wish list)
- gift from someone at work today
- I hate each and every single one of you...
- dash swap, glove box differences
- I'm back!!!!
- throttle body cables 97sc
- Does my HIC USA sc300 roof spoiler fit right?
- USA gas octane ratings versus Europe & Japan (RON vs AKI)
- Control arms
- Fuel Relay or Ignition Switch?
- Found an old article for the SC400 (1991)
- One Thing I Noticed About ClubLexus or Lexus Forum In General.
- Should I leave the SC and go to an LS
- Review on the APTech Aero Craft Poly-Urethane Body Kit
- a few diy while i wait for my ecu..
- New/Old SC owner
- Drive shaft-What is this part called? Part Number?
- help me pick wheels
- Who will be joining me
- KBD Premier Front Lip
- Weird never seen before cluster problem
- 93 SC400 timing
- how did u acquire your SC?
- tell me im not crazy CL
- Brake locking problem.
- Best lighting for speedometer?
- Power steering delete?
- Sc300 Motor Shut Down
- 1st gen SC crashes at over 100 MPH but holds up pretty well
- Will a 275/40 +40 19x9.5 fit in front?
- $350.00 quote for new key.
- Turbo information help
- trying to track down the part # for VSS#2 - 95 SC3
- Aftermarket head unit for '92 SC400
- If I sell my SC should I get a 350z or Crossfire?
- These SC's make pretty good race cars, results from Daytona chump race last weekend
- Lextech lighting is back online, BEWARE CL USERS
- Starting with a shell 1JZ project
- Bringing Back an Old Flame
- Changing valve cover gaskets on stock 2JZGE
- Alignment in Austin Texas
- 10 years later...
- IAC valve wiring connector
- 2 part numbers for 97 bumper?
- Bright Leather colors for reupholstery?
- Battery Light Issue?
- Farewell Photoshoot of my SC!
- Dash Refresh
- What are some must have cheap mods?
- 1/120 SC mentioned in Jalopnik article
- Airbag resistor ohm anyone?
- All WTB Threads Go In The Classifieds Section
- Almost complete black interior
- Vent-Duct Formation?
- Closing deal on a 98 MK4 TT
- Finally, purchased 99 sc400
- my 95 used four double O
- USDM 2jzgte ECUs
- where to paint and how best
- SC400 Top two Bell Housing Bolts HELP!
- Removing driver side air vent-93' SC300
- How to purchase a car from someone on facebook?
- keyless entry system not working after removal of cluster gauges
- rear taillight moisture penetration
- Help Finding Valve Stem for my Rare? Wheels
- back with a 97 sc400
- How would 19/275/40 9.5 +40 look on a lowered sc???
- code 24 need advice
- Fender rolling
- Quick easy question maybe you guys can help
- Any idea what rims are on this SC?
- Leave ABS ECU unplugged?
- where to put the jack?
- Oem engine bay color codes
- Need Help: Will the real color code 051 stand up
- Best way to sleep?
- Question about 94 sc400
- 1995 lexus sc 400 regular vs premium gas
- Shine front bumper fitment
- Bad ignition switch quick help needed.
- It's been real.
- My UZZ32 Soarer No.32 of 873
- Original Owner of a 1993 Lexus SC 400
- ebay (lower mileage 150k) or local (high mileage 270k)
- How does everyone go about rolling fenders
- 18x10 +12 offset with roll and stretch ?
- Tubing
- why does everyone suggest a GTE swap
- Help with door mirrors up and down motion dead
