- How to check Auto Transmission outside of car
- bosch 760cc injectors
- Alternator Issues
- Intercooler tuck..thoughts
- 92 sc400 reverse wires? w58
- Sc400 1uz-fe dtc 29, 31, 41
- Help finding Soarer 1JZ!?
- Clunking noise in the differential
- Car trouble
- 2jzge auto-manual differences?
- 1JZ GTE VVTI Spark Plugs & Gaps
- 240sx trans
- HELP!!! 1jz turbo downpipe???
- I need input
- Heater Problem SC400 1995
- Transmission Jerk, Surge, Clunk shifting to Reverse and Drive
- auto to manual conversion...mechanics
- temp gauge sender.. does it have a washer?
- Need help from someone with a soarer 1jz swap
- Pontiac Transmission = R154?
- Car stalled today, Fuel pump ECU?
- 1jz-gte swap questions
- 94 SC300 tail light fuse keeps blowing
- Soarer downpipe/y-pipe/dump pipe same as Supra?
- Power Steering Pressure Hose Removal for SC400
- Horsepower freaks ECU?
- what causes oil leaks in the front of the motor?
- help with belt squeal and power steering pump
- New PS pump or seal rebuild kit?
- driveshaft whole or half 1uz to w58 swap
- Any shops in Dallas that focus on JDM engine swaps?
- 95 sc 300 power steering fluid disappears
- washer(?) rattle with MKIII R154 driveshaft after carrier bearing swap-- advice?
- SC400 starting issue
- sc 400 won"t keep running
- 92 sc400 ATF Type
- Oil Leak?
- Power Steering Leak
- 92 SC300, CEL and High Idle
- Possible corrosion in turbo?
- Idle gremlin again
- Turn key and most horrific loud grinding sound ever.
- Which Fuel Pump? 1JZ GTE VVTI
- intercooler piping super close to crank
- Power steering pump for 1999 SC400
- Anyone know where to get a Transmission for a Sc400?
- Bone stock r154 clutch limits
- help deciding on what to do for my custom sc400 exhaust
- Car dies after plugging in MAF
- My Supra TT Denso Fuel Pump Install
- Motor turns no start condition - 1JZ SC300
- Kaboooyaaa !!!!!!!!
- Show off your Nitrous Install!
- FPR and Filter Recommendations
- maintenance what i need to do
- 1jz vc to turbo hose?
- Had my rebuilt R154 transmission installed yesterday (initial impressions)
- Still no cool air
- Tial BOV Spring Rate 1JZ
- 1jz wont start
- If 1UZ MT, its better to install the supra tension damper?
- ignition problems, any recommendations?
- Major NA-T dilema. Can't stop now
- 1jz preventive maintenance
- Water pump gasket?
- SC300 won't crank
- After Market Exhaust
- Throttle Getting Stuck Under Boost.
- TOTALED? thanks 24 year old female...
- Sc400 limited slip options
- SC400 transmission short question
- plz help! Cant remove Left Front Rotor
- Complete 350z trans swap 2jz
- 92 sc400 152k
- Please Delete
- Schley 64300
- Engine Code 28
- Exhaust fitment question
- Rough Idle, Engine cuts off
- Question Re Electrical Connectors
- Alternate Fix for Loose Shift Lever
- SC300 shutting off while braking
- Water pump torque -- kind of urgent
- 2JZ water pump question
- no spark
- Rein hard exhaust?
- Jzz30 fan/clutch same as jza80 fan/clutch?
- 1.5jz build options for harness
- Need Clarification Re SC400 Shift Lever Repair
- 1jzgte sc300 swap question, swap experts come!
- 2jzge w 1jzgte harness
- Ready to start 2JZ timing belt job
- FFIM Install on 2jzge
- Dipstick/Oil Pan Question
- Need advise
- Single turbo? splutters bad with vacuum connected to FPR
- Resonator Deletion/Replacement?
- Tranny filter
- Code 21 Solar Sensor. A/C wont work!
- sc400 w58. no crank.
- Putting 2jzgte engine back in car have sensor and flywheel question
- Passenger door won't open from inside or outside
- Garrett Turbo
- 1JZ spark plugs?
- 2jzgte Single turbo boost issue...
- axle came loose while driving.
- Aem piggy back help
- ABS Light Trac Light need help
- Ring and pinion replacement on differential? Pics i need help!
- My SC400 manual conversion
- Definitive information on the tach differences of the sc3 and sc4
- Help me Identify this flywheel
- clutch pedal creak and bypass?
- Part ID request
- Steering Pump Removal Dilemma
- 1jz coil cover options?
- Soarer Trans
- Srsly, what is that?
- Any specific tips for SC3 timing belt change?
- DLC connector does not work! 93 SC300
- Megasquirt MS3 with 2JZGTE?
- Help! NAT feels like a misfire?
- Building 96 300 parts locations?
- cluster lighting/bulb question
- Remove driver side air vent
- Replacement OEM Heater control valve two part numbers?
- Slight steering shake at highway speed?
- M2 performance axlebacks for sc300/sc400
- GTE wiring swap help
- machined head @ .010, what headgasket? 1jz
- Transmission year compatibility
- Map Ecu 1
- Entire SC dash removal to access A/C evaporator core... or just part of it?
- Engine will not idle
- 1jz/2jz rear sump oil drain elbow
- 95 SC300, 2jzgte swapped (bad block), current setup questions
- automatic headlight swap?
- V160 vibration problem
- SC400 short circuit
- Gauges not working after bulb/needle replacement
- Intake Vacuum Line
- Stereo Question/Sub works the rest is intermittent
- sc300 miss firing issue
- 92 SC 400 coolant leak
- sc300 transmision a650e
- Need Help with Dreadful Electrical Issue!!
- Cheap LSD options
- Fuel tank help.
- head light wiring diagram?
- 2jz sensor locations
- 1jzgte vvti swap help
- I need help! Ugh.
- SC300 owners, any benefit for a cold air intake?
- Aftermarket Fuel Injectors
- Codes 21,24,61
- Where is the most reliable place to get GTE engines?
- Need Help Finding a Soarer Clutch Master Cylinder
- flywheel stuck
- 2JZGE VVTI Head Swap on 2JZGE Non VVTI
- Bad/Rattling A/C Blower Motor?
- Fuel Starving under 1/4 tank
- 92 SC300 Stalls randomly
- More idle issues, need some suggestions from the CL members
- Interchangeable timing belt parts question? SC300 and SC400
- What is this part attached to the throttle body?
- Idle speed control changed
- fixed A/c new fuel filter now starting idle and smoking problems
- Metal shavings on dipstick
- Fuel/Gas Fumes
- Who wants to play a game?
- Supercharging with Fish Bracket...
- Replacing Throttle Body Coolant hoses (water bypass)
- SC300/400 and MKIV Supra A/C condensers physically the same?
- Cases Of Fires?
- Are 1jz front and rear turbos the same?
- DIY: Tap 2JZGE Valvecovers for fittings
- Replacing Throttle Body Coolant Lines / Water Bypass Hoses
- Help with my oil light.
- Soarer clutch issues. Need part numbers
- timing and were should it be at idle
- Big MPG Improvement
- Misfiring after MAF cleaning
- 1jz swap does not throw trouble codes
- How to check your chassis for LSD
- 1994 SC400 engine fire need interchange info
- turbo question
- DIY: TT Mishimoto Radiator Install with JZ swap and Soarer fan shroud
- 1999 SC300 transmission swap help
- 1JZ Running Rich: Bad ECU Capacitor?
- 95 sc400 A/C probles
- Recommendation Re Common Problems
- Help my ex girl friend stold my only key =/
- Aeromotive fpr help
- Upgrade time to 2014 NA-T
- 1/8 throttle jerking, 2800rpm power jump
- how to test an icav
- 2JZ GTE 6-sp manual swapped into 1998-2000 SC300 with auto trans?
- Oem vs aftermarket molding
- Found a vacuum hose unhooked that goes into my vsv
- Found a vaccuum hose thats plugged with a screw help identify please
- weird idling problems
- AC Leaks 1992 sc 400
- Do you trust your local mechanic or reputable shop or do it all yourself thread????
- suspension question
- Boosting options?
- SC300 Catback Exhaust onto a SC400?
- electrical issue need help 93 SC 400
- 92 SC300 Engine
- Fuel Pump Strainer
- How to bypass fuel cut past 14 psi on aristo ecu (not a typical thread)
- Power Steering Solenoid
- Need help asap!!!!:(
- Left tail light completely out after cleaning sockets
- Supra dyno pull!
- Aristo/sc300 wiring question
- weird sounds :(
- sc300 fuse issue
- I really need help!!!!!!
- sc300 soarer swap will not rev!?!
- 1JZ SC300 will not rev past 2000 rpm STILL!
- JDM Engine Importers
- Excessive Play sc400 Shifter Lever
- DIY: How to install HEADERS V8. Rush headers long tube
- cleaned throttle body, and idle
- Rough riding issues, need input?
- replace coolant with water? and bleeding cooling system
- who has cleaned their Y-pipe
- 1993 sc300 wheel bearing wires????
- SC400 Code 25 Lean Air-Fuel-Mixture
- Best close ratio final drive for R154 2JZGTE w/twins at 320hp-to-BPU ONLY?
- Fuel pump ECU(refurbished ecu's)?
- SC at the track! !!!!
- Changing tranny fluid w58
- Car wont start?
- enigne error code p1381
- How a Karmen Vortex MAF Works
- My first lexus EVER!!! SO AMP'D!!! Have a few questions
- Oxygen Sensor OE or Universal
- ECU In Default Mode
- High idle and smoke...super puzzled
- power steering issues, major
- 1jzgte non vvti tubo questions/opinions
- My SC400 Pings like crazy when I shut it off
- Should I buy this W58?
- 99 sc300 loss of power.. help ?
- Janky SC400 probs
- 1jzgte vvti wiring mod.
- new fuel pump issues
- Trans build up thread
