- Suspension Problem
- Tranny issues
- Torque settings / Fluid quantities
- Clanking noise
- fog light bulb replacement
- Engine start problem
- VSC Check Engine on
- rear & front end oil question
- Interference Engine
- Replaced O2 sensors...still getting CEL
- A couple of questions regarding dark fluids.
- Problem replacing headlight bulb
- Display Panel "Glitch"??
- Battery?
- any advice on hookind up a new sub and amp?
- Good Deal : Replaced timing belt+ for $666
- 120,000 mile "service"
- Update on Kumho Slus Tires
- clucking/chattering front wheels
- Excess tranny oil level, please help!
- I think my tranny is leaking.. Need Help!
- new in my driveway 2002 RX300...now what?
- Center console and Auto Door Unlock
- I don't know wtf is going on!!!!!!
- what did i get into???
- '00 RX300 no volume
- 01 rx300 flashers will not turn off
- rx300 with 18" btl
- 03 RX300 Starting Problem
- Fuel milage computer
- Trans fluid color?
- P1150 And P1155 - Help With Codes
- how to change fuel filter on lexus rx300
- Ashtray Not Opening
- 2000 FWD RX300 transmission interchangeable?
- Cruise Control Issues
- another RX transmission failure
- im going to make a suggestion here....
- ABS Light
- transmission drain bolt or plug
- ABS Warning light on when rain
- Would you get this?
- Aftermarket HIDs
- Pulsating Brakes- ABS Problem?
- kenstyle body kit
- Brake Pad Thickness Measurement
- Fuel Full at Half Tank?
- Steering Wheel Vibrates at low speed and then around 75mph
- New Key
- P0420 Code?
- fl replace
- stereo system qustion?
- JP Performance header
- keyless entry
- Funny speeding ticket
- Where is the block heater located?
- Warped Rotors... but which??
- RX a bit twitchy on the highway?
- Retailer Questions
- Did anyone....
- Question
- RX300 Transmission problems
- Shuttering and Traction Cntrl Light Upon Acceleration
- Steering wheel movement
- Engine chugging while cruising on freeway
- High Pitch squeel?
- No heated seats???
- What about DICE Ipod/XM interface box?
- Another hid question?
- What is a resasonable mileage for an RX300
- Squeaky rear end
- What the heck is this noise?
- MY 00RX 300 vibrates at 65 MPH
- 2003 RX300 Transmission
- Window tint film
- cold day behavior
- Just Purchased 02 RX300 - Buy the Extend Warranty??
- 235/65-16 tires
- Trouble starting at 23 degrees
- Serpentine Belt change
- How can I switch from MPG to KM on my '00 RX300?
- Weapon R SW intake
- pads and rotor, I've tried to read as much as I can. pls help ^^
- Change Air Filter - Car Won't Move
- 1999 Rx300..help..help..
- tire: final question :-)
- cel and codes
- No oil in oil filter
- Is the 18" sc430 rims going to fit the 01 RX?
- Looking for Rx300 chrome CENTER CAPS for stock 16" wheels
- Window Control Problem
- 255/50x18 tires on std rims
- Sticky accelerator
- I hate my antenna
- Cel P1130,1135
- Where can i get a Owners Manual for 2000 RX300
- Please help w/99 RX300 - electrical?
- i am looking for a TAN interior trunk panel (TOP piece)
- My clock resets everytime i start the
- Car shakes when braking while turning left
- Front Differiential
- Shocks/Struts for 1999 RX300
- Warning lights
- Difference between Rx300 and Rx300 Silversport
- CEL & No O/D
- Rx300 vs cayenne
- What CEL (check engine light codes) have you had?
- CEL P1150 Code
- Question for lexmex
- 22"
- Royal Purple Trans Fluid
- Dome light question
- important question...need an answer by friday :-\
- 99 RX300: Heating and Shaking Problems
- Fuel Filler Neck Spring Hinge
- Idle Air Control Valve - should I just buy a new one?
- Air Conditioner 24/7
- 99 RX300 won't start/turnover - Need Help asap!!!
- Continues to Run after Turn-off
- Squeaky Fans
- Shocks KYB GR-2
- Ripped rubber boot (rear shock)
- 2000 RX300 probable transmission problem
- new member, looking to buy used
- Hid?
- RX 300 Pinging
- Transmission fluid
- Best Way to Sell my 2001 RX300??
- Engine Check Light = $1200?
- Wheels that fit RX300?
- RX Chrome Grill
- Navigation "no disk detected" message
- my sig: read the writing not the pic
- 99 RX300 Center Console Lights Out...
- Question regarding check engine lights
- shaky tranny
- driver side power lock and power window acting up...
- Wheels - aftermarket
- Any experience with Castrol Synthetic ??
- Is changing the cabin air filter essential?
- Rear Hatch Strut
- DVD Navigation Upgrade DVD installation
- Crush Washers FYI
- Programming a used master key
- Need your help guys!!!!
- Key Blankets needing to be cut
- Heater controls dont work anymore....
- Glove Box Rattle Fix?
- Front Seat Removal
- Vsc and engine light came on - any suggestions??
- High RPM when cruising
- Check Engine - P1153, & P0446
- Dashboard Access
- Door Ajar Dash Light WOn't turn off?
- RX300 Engine + Transmission Issues
- Need Help - Error Code
- Passenger side mirror malfunctioning
- 17 inch wheels
- Changing tension pulley, idler bearings with timing belt change?
- Lets ask Lexus to bring back the RX 300!
- Question for lexmex?
- Rims
- Draining the Block?
- 16 inch custom wheels
- Serpentine Belt (2 Belt) Replacement
- Question regarding 2000 RX 300 transmissing problem
- When should antenna extend
- Newbie Questions, Outside Temp Gauge, AC Filter, Rear Differential
- Has your RX 300 surpassed 200k miles??
- Hi, just purchased used 2000 RX 300 AWD
- Air Intake Shield Idea
- One more question about Synthetic Oil Please!
- Quick Help!
- Transmission?
- Use of Amsoil Oil Filters.........
- Crush washers for diff/transfer etc.
- Changing over to Amsoil. A few important questions.
- Group Reward Possibility?
- New OEM Parts Ordering Site
- CD changer?
- Mobil 3309 is ok?
- Chattering front right during accelerating from stop.
- Check Engine Light
- auto transmission
- Lexus Minivan spotted in Hong Kong
- RX300 extended warranty deal breaker..Help!!
- update for 2002 navigation system
- Hid Headlights
- Synthetic Trans fluid...........
- Who makes the best HALO
- New to this forum. Couple questions.
- Absolutr requirements at 90K service???
- New Set of Kumho Solus Tires
- Heating Driver Side
- Idle-Warm up Question
- Check Engine Came on this morning
- Upgrading/accessories questions
- question about other calipers ...
- Surging while braking then engine dies
- Eastern,Pa
- Trans Fluid Flush?
- driver side front signal turns on when brakes applied
- Pulsing head and tail lights
- Another "what should I look for" in buying a RX300 Thread
- Steering Wheel makes funny noises :S
- ebay rx300 grill
- Rear brake parts photo
- dead bulbs?
- Wheel stud question.
- Brake question
- High RPM when temperature is low but not so low
- RX300 engine
- Noise when fan is on
- Odometer problem. HELP!
- Switch front seat cushions?
- Brake crew, need advice.
- Rear Power Outlet Rating
- What is the best MPG you ever recorded?
- Troubleshooting
- maxing rims
- Something went bump :(
- 2000 RX purchase
- Leaking Water Inside Cabin Help!!!
- It's hip to be square (new resonator)
- For mechanical genius's only....idle tweak...
- When did you change your battery?
- What are the correct torque specs for the transmission pan bolts?
- Sticking Central Lock System
- darn!
- My car won't stay on....
- brake light out - how to get to it?
- sensor trouble
- Frequency of Air Filter Change???
- Short fuses
- C-Best headlight turnoff delay
- Replaceing Front Side Marker Lamp
- in-line transmission filter?
- Help Lost Keys!
- Lucas Transmission Fix
- Trunk strut replacement?
- Rear Driving Lights Out
- online oem discount sources
- Rattle in A-Pillar Speaker Tweeter
- Roof rack paint pealing
- odd repetitive noise coming from rear wheels
- perfect combo
- front wiper problem
- Thanks already--from an RX Noob
- Quick question, fix it and keep it or forget and trade it
- Electrical Mayhem inside our 99 RX
