Royal Purple Trans Fluid
Old Jan 9, 2008 | 07:58 PM
carguy07's Avatar
carguy07
Default Royal Purple Trans Fluid
Max ATF is a synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life.
Who wants to be the guinea pig? Supposed to cross over with Type IV.
Old Jan 9, 2008 | 08:07 PM
3000's Avatar
3000
Nah, I think I'll stick with Dexron Mercon III. It's expensive enough already.
Old Jan 9, 2008 | 08:10 PM
gsrthomas's Avatar
gsrthomas
I just did a flush not to long ago.
In 20-30k miles I'm going to do a complete flush my droping the pan and replacing the tranny filter with a new one and using Amsoil Tranny Fluid for the first time.
Old Jan 9, 2008 | 08:12 PM
thomas1's Avatar
thomas1
How much does it cost? Probably take around 12 qts to do a flush.
Old Jan 9, 2008 | 08:32 PM
carguy07's Avatar
carguy07
$10.95 a quart.
I think I am just sticking with Toyota fluid for now and dumping the pan when I do oil changes. Too easy of a job to not drain and fill a couple times a year.
Old Jan 9, 2008 | 09:10 PM
Lexmex's Avatar
Lexmex
I might have tried it down here if they offered it at that price. Royal Purple is available through a few distributors, but they charge you 2x the price in the U.S. for the stuff.
Old Jan 10, 2008 | 02:32 PM
sonyman's Avatar
sonyman
Amsoil is probably the best you can buy, and cheaper to boot.
Old Jan 10, 2008 | 03:00 PM
lexus114's Avatar
lexus114
If I can find it,Ill try it.I already use royal purple engine oil.And like it very much,rx runs good on it.
Old Jan 10, 2008 | 06:44 PM
carguy07's Avatar
carguy07
http://store.summitracing.com/partde...5&autoview=sku
They claim it will cross over: http://www.royalpurple.com./transmission-chart.html
Please let us know what you think. I would love to switch to synthetic when my warranty expires.
Old Jan 10, 2008 | 08:53 PM
HarrierAWD's Avatar
HarrierAWD
Here's a general price list. Use whatever you wish.
Dexron/Mercon - $1 / quart (cheap, for GM/Ford)
Toyota Type-IV - $4.70 / quart (what I use)
Amsoil - $8 / quart (discount for "independent distributors")
Royal Purple - $10+ / quart (priced to screw royally.)
Not to butt head with the independent distributors or stop their gravy train, though I find the genuine Toyota Type-IV the best for my RX300. 115K miles in harsh Colorado mountains and climate, never a problem. Why experiment snake oil with your $40K vehicle when there's a trustworthy and proven product? Again, use whatever you wish, just gather all the facts first and filter out marketing ploy.
Disclosure: I have no financial incentive with Toyota product.
Old Jan 11, 2008 | 08:43 AM
Lexmex's Avatar
Lexmex
HarrierAWD,
Just curious since we are both at high altitude, how often do you change out your ATF?
Royal Purple charges about 200 pesos per bottle, just under $20 USD here for ATF last time I checked.
Old Jan 11, 2008 | 07:53 PM
HarrierAWD's Avatar
HarrierAWD
So far my ATF has been changed at
30K (drain-n-fill by dealer)
60K (drain-n-fill by dealer)
90K (drain-n-fill by dealer, though I suspected the dealer didn't do jack)
95K (3 times myself)
110K (2 times myself)
I plan on doing twice again at 125K.
The ATF level stays constant, so apparently no evaporation issue despite the altitude and low humidity. Are you seeing differently in Mexico City? I live at 6,100 feet, believe M.C. is about 7,700.
Old Jan 11, 2008 | 08:40 PM
Lexmex's Avatar
Lexmex
That is about right on the elevation, higher in areas around the city. Water/coolant tend to have severe evaporation issues here, but I haven't been fully able to ascertain other fluids.....yet.
lexslexus
Mar 30, 2018 01:56 PM
lexusben
Aug 19, 2011 06:19 AM
margarita
32
Apr 10, 2009 07:06 AM
cdvmagic
Maintenance
Jan 31, 2007 11:44 AM
HotBoy
Maintenance
Dec 30, 2003 09:09 PM
