What are the correct torque specs for the transmission pan bolts?
What are the correct torque specs for the transmission pan bolts? I saw in this post ...
https://www.clublexus.com/forums/sho...d.php?t=220061
... that you should "tighten 18 pan bolts to 69 inch-lbs" -- but that seems like a lot of torque for those little bolts. Is this correct?
Please post. Thanks!
Scott
Scott
Also, build the squeeze evenly by following criss-cross tightening process.
Salim
Salim
I worked on my son's SC transpan. That required FIPG and since then I never opened the pan [for me it is drain and fill].
For other things that require a gasket, I only use sealant on one side.
Salim
ps: The sealant should face the part that would be easy to clean in future disassembly.
Salim
Just divide by 12, so 5.75 ft/lbs. But make sure that your torque wrench will give you accurate readings that low. If it is only in ft/lbs I doubt it give accurate readings on the low side. I would just snug down by feel.
That is exactly what I have done. Pick up those thumb rachet to save time. Your right arm will thank you.
Sealants on transmission pan
As for sealants on the transmission pan, I have been told not to use gasket sealants as they may cause imperfections in the seal of the pan. I was instructed to use brand new transmission oil and rub on both sides of the gasket just before installation.
Cap425
GX - 1st Gen (2004-2009)
07-06-18 05:29 PM
LsG86
17
02-19-15 07:41 PM
