driver side power lock and power window acting up...
Old Dec 31, 2007 | 07:12 AM
Yellowbro's Avatar
Yellowbro
Default driver side power lock and power window acting up...
anyone here have any suggestion to troubleshoot this problem??? i haven't fully looked into this problem yet...will prob troubleshoot it tomorrow...
1. power lock...when i press the lock button on the keyless entry or even on control panel at the door it doesn't work...u can see it trying to lock and unlock...but it doesn't do it...as if the solenoid/motor isn't actuating...
2. power window....when i roll down the window but not all the way...it will not roll back up unless i roll it down all the way first...then it will go back up...and when i do try to roll it back up when it's not fully down...it will go down anyway instead of up when i push the up button....now sometime when i let it roll all the way down...it will sometime not roll back up unless i give it some time or take the key out and put it back in...
could it be the whole control assembly??? or just two independent problem???
Old Dec 31, 2007 | 07:27 AM
thomas1's Avatar
thomas1
The door lock problem is probably a bad actuator assembly, cost about $250 for the part....As for the other problem, unhook the battery for 5 minutes then hook back up and try again.
Old Dec 31, 2007 | 07:43 AM
Yellowbro's Avatar
Yellowbro
i don't frequent this forum too much....is the actuator assembly going bad a pretty common problem amongst rx owners??? also is this actuator common parts amongst any other lexus vehicles??? i'm gonna try the junk yard...
for the power window...will try that one tomorrow...
found this thread while searching... https://www.clublexus.com/forums/sho...uator+assembly
Old Jan 2, 2008 | 10:11 AM
DigitalEye's Avatar
DigitalEye
I'd say its a reasonably common problem in at least 99/00 RX's. I'e got it with mine and I recall a number of others mentioning it as well. In my case the drivers door wont lock itself with the remote but it will un-lock with it about 95%of the time. I've simply gotten into the habit of flicking the lock closed when I get out of the vehicle and barely notice it as a problem anymore. It tends not work when the car has been in the direct sun for a while or its very warm out. I've looked into tearing the door apart but I've never mustered the courage to do it.
Old Jan 12, 2008 | 07:30 PM
OceanView's Avatar
OceanView
I am having a similar problem but what happens to my car is that the door will unlock with the remote but I can't open the door from the outside but I can open from inside the drivers side door.
Also, when I roll the window down, there is a grinding sound that was not there earlier today. I wonder if the window got off track or something.
Any ideas?
vanchaz200
May 18, 2015 01:34 PM
gizmatix
Jul 16, 2012 10:52 AM
mastersak
Apr 2, 2012 09:20 AM
p1fcl01
Jun 8, 2003 12:41 AM
