Chattering front right during accelerating from stop.
Old Dec 12, 2007 | 06:31 AM
bryan.root's Avatar
bryan.root
Registered User
Unhappy Chattering front right during accelerating from stop.
When accelerating from a stop I get this chattering sound, braking sensation. It seems like the anti-lock brake is coming on, stops after a few seconds and all is OK. This happens maybe 1 in 6 or 7 starts. Has anyone:sad: experienced this on there RX300 or other vehicles? Please e-mail me if you can offer any solutions.
bryan.root@comcast.net
Regards
Bryan
Old Dec 12, 2007 | 06:55 AM
thomas1's Avatar
thomas1
Could be your speed sensor on the right front wheel. It may have debris on it giving a false indication. can be removed and cleaned real easy. It has wires going to the front brake assembly and is held in with one bolt. The other thing is your right half shaft may be worn. But I doubt it. Check and make sure the rubber boots on the drive (half shaft) are not torn open.
Old Dec 12, 2007 | 07:00 AM
salimshah's Avatar
salimshah
25 Year Member
How hard do you accelerate and how good (treads ) are your tires and also what is the condition of the road. If traction is poor and the wheel is just spinning then it could be normal behavior.
Salim
Old Dec 12, 2007 | 07:32 AM
bryan.root's Avatar
bryan.root
Registered User
Default Good things to check.
I will check the sensor.
If I let go of the brake it start moving forward no problem.
When I give it the gas (not any speed starts, just normal), sometimes I get the pulsing/grinding noise.
Car actually dive a little to the front right and slight turn to right.
Dry pavment, level road, air pressure same, good tread.
Thanks
Bryan
Old Dec 12, 2007 | 07:34 AM
thomas1's Avatar
thomas1
I would check speed sensor, but maybe you have a caliper hanging up...
Old Dec 12, 2007 | 08:28 AM
lexus114's Avatar
lexus114
bryan,I had the exact same problem when I first got mine. Evidently the traction control system (vsc) uses the antilock brake/speed sensor.This is what I did to remedy the problem,you have to do this to all four sensors,take the wheel off,locate the speed sensor,take it out (10mm wrench i think it was) clean it with wd-40 dry it well,I also used a can of office duster (optional) Re-install,problem solved. In my case,the sensors were loaded with debri,tiny metal particals that stick to the magnet,on the sensor.Remember,for best results do all four wheels.
Old Dec 12, 2007 | 10:44 AM
bryan.root's Avatar
bryan.root
Registered User
Thans for all your help.
I will look at the sensors tonight.
Old Dec 12, 2007 | 06:58 PM
carguy07's Avatar
carguy07
Glad to hear that's all it was!
That one should be pinned somewhere for future reference.
Old Dec 13, 2007 | 08:22 AM
Lexmex's Avatar
Lexmex
Here is the thread with the photos of the areas of these sensors,
https://www.clublexus.com/forums/sho...d.php?t=285023
M45owner
56
Mar 19, 2026 06:44 PM
KingNasGS4
Jan 8, 2012 06:07 AM
sveinongen
Mar 11, 2010 04:37 PM
81corolla
Dec 13, 2009 07:55 AM
