View Full Version : Maintenance
- sc emission problem
- Master & Tire pressure warning light
- Rear window defroster not working
- New struts or just mounts??
- What's the difference between a drain/refill and flush?
- Oil change!!
- How often are you supposed to change major fluids?
- Window Moulding replacement
- comments on mobile 1 oil ?
- Time for a Timing Belt?
- No Get Up and Go
- 99gs400 left key on and now wont start
- Got new tires. Should I do 4wd alignment?
- straight answers about brakes - is350
- U R G E N T....I need a knowledgeable mechanic's help
- P1071 error code
- Found new way to improve transmision performance.
- Timing Belt ????????
- 02' GS300, CEL help P0125
- Radiator is300
- Problem- (not a Lexus), 11.9V on alternator on cavalier...
- Have a Popping Noise in Front of Vehicle
- IS-F Brake Transplant
- Extended Warranty Question
- timing chain or timing belt
- how do you replace a 92 sc400 fuel pump?
- Could This Damage Your Car? Engine Flush
- So SC400 P/S
- Help please!
- Can't get the DARNED hub off!
- part number
- Fuel Additives
- Torque specs for spark plugs.
- 2000 Lexus GS 300 - A/C stuck on High
- SC400 Heater control valve?
- Cabin Air Filter Recommendation?
- What are the stock plugs in 00' GS-300?
- Transmission - 98' SC300
- Engine coolant liquid spilled all over my engine bay and dried up...
- Type 2 trans fluid (HELP)
- power steering noise (HELP)
- Fuel System Treatments for a New Vehicle
- 94 sc400 heat question
- Lease maintenance
- Blew a bunch of fuses/relay
- 99 GS 300 Serp Belt
- How to shut off "Oil Maint Reqd" warning light
- Valvoline synthetic oil
- Locating fuse box on GS 300 1993
- 02 RX 300 anything I should be aware of before changing 3rd. brake light bulb?
- Just what exactly is inside that oil filter?
- 92 SC4 jerking at high speeds HELP
- Power Steering problem
- in my sc400, my door cant lock from the inside.
- can't clear code.!
- Battery Report
- Removing Mirror
- Honda valve cover with 250k & AMSOIL vs Lexus valve cover with 112k and mobile one
- Synthetic oil misconceptions
- A/C system question
- Switching to synthetic next oil change...
- MAF problems etc
- How Much Did U Pay For Your Timimg Belt Change?
- replaced MAF still bogs down at light throttle.
- test thread
- WOW ... am I getting banged in the head?
- Maintenance costs at dealer
- Differentail Question SC300
- www.asedeals.com (Tools)
- Dead New Battery
- 08 RX350 DIY Coolant Drain & Fill?
- Viscousity
- Is All FIPG the same?
- [HELP] Passenger mirror, power lock, and door light doesn’t work after audio install
- Service questions
- SC400 A/C Drier question???
- Starting problems shifter/ keyswitch quirks
- Switching oil in the beater...
- Changing Transmission Fluid On A 99 GS 400
- 92 SC400 A/C question????
- brake vibration
- General Question?????? Help
- Bleeding the brakes
- General Maintenance question...
- Can I use Amsoil ATF when my tranny requires Dexron II??
- Engine hesitation, power loss, sluggish acceleration: Potential fix
- Need some advice... transmission
- Transmission Filter
- GS430 Servicing
- SC300 steering wheel won't go down!!!
- Turns over but wont start. Alternator fuse melted. Timing belt issue?
- Lexus Red fluid VS name brand
- Changed oil on my '08 IS350 today
- 92 SC400 Suspension problem?
- How do you remove steering wheel on sc400???
- can oem is250 rims fit in sc300
- wheel alignment done and still drifts to the right
- Does anyone use K&N air filters?
- 2nd gen gs trans
- Jump starter vs. jumper cables vs. roadside assistance
- Recommend an ATF
- 30K miles service
- Fan not rotating fast enough
- Weird Experience at local Lexus Dealership.
- royal purple ATF
- Brake Wear Sensor, Can it really be soldered?
- Help with mysterious hose
- AAMCO Power Purge® Plus Transmission Flush & Filter Change
- Torque Specs
- Is it time to replace my air filter?
- Sc300 oil leak problem
- sc300 rear seat
- sc300 trans swap
- what do you do with your old oil after you change it yourself?
- sc300 ac problem
- Rear brakes question
- a/c not blowing cold. code 43???
- 00' SC300 A/C Short Cycle
- A/C Issues on hot days
- Wiper prob.?
- What is leaking now :( ?
- Brake Squeeking Question
- Air Intake Filter
- Which fluids to Use ?? Oil, tranny, diff, brake ?
- oil change
- how to replace a/c air filter forsc300
- blue smoke on startup
- i should start tuning-up my new car? =)
- Dash removal
- Engine problems? Sc400 + pic
- seized caliper
- suprising results on motor oil test
- BG Power Steering Fluid, Flush?
- sc300 shifting probems
- Need Help!!!!!
- Mobil 1 5qt. jug?
- Wheel Touch Up paint
- 2000 es300 check engine light
- catalyst converter bank 2
- Concerns with my 1995 es300 transmission
- No CEL with key in "on" position?
- What is the best way to clean these parts
- Redline vs Amsoil motor oil
- Need to do Timingbelt and etc, Socal area, please advise
- Indy in Houston area?
- what Oil are you running
- OBD-II Reader to Hookup to a Laptop via USB Port?
- Oil filter question
- had the maf cleaned and car stumbles?
- '06 RX330 Rear Camber Adjustment??
- re calibrating traction control
- '06 RX330 Rear Caster and Camber Specs??
- I turn the key and nothing??
- Time For A Tune Up. Need Some Advise
- 90k Maintenance?
- 95 Supra repair manual
- 0W Syn Oil From Mobil 1
- Remove Flaher Unit??
- Shop Manual
- Weird problem with my car... My key doesn't even work?
- Which one to adjust
- Tranny replacement questions?
- Looking for online parts places with diagrams
- Head gasket replacement on sc300
- Alignment problem w/ caster (SC300)
- Where to buy oil filter of IS350
- 10PA20C oil requirements by volume
- Is all this really necessary to change belts?
- oem service manuals on cd -cheap-
- GRRRRRR what size Gasket?
- AC Denso Compressor stucks will gear on P
- any ideas about these error codes ??
- Is there a DIY for Valve Cover Gaskets for SC300
- The verdict after a Lexus inspection
- 2004 LS430 AC Compressor
- No coolant
- Does this seem high to you?
- Battery Drain... A/C blackout... Related?
- How much pressure to remove bushings?
- lucas transmission thing
- Sea Foam Informative Info
- Liquids DIY?
- $800 for a check up!!
- LS400 rear swaying like a ship
- Service in MD
- Problems after engine cleaning
- Replaced 2 Lexus Radiators - DIY comparo
- oil light flashed...
- SC400 service manual - Will '94 work for '95 TB replacement?
- SC400 timing belt change - what parts to get?
- Synthetic oil or not??
- Brake problem only one 1 wheel
- Tire Rotation Pattern?
- Consequence of too much engine oil
- I know I know, more timing belt questions...
- Hooking my battery back up issue???
- Once again,Does anyone use Non-OEM Oil Filters?
- 2000 GS400 Hesitation / Check Engine Light
- Window help
- surging reverse
- laundry list of recommended maintenance from dealer
- Using 87 Octane in 1990 LS400
- n00b questions about 160k service (similar to bb7110 post)
- A/C light blinks on and off, air gets hot, resets
- Brake Sqealing
- anyone used "E3" plugs? are they worth a crap?
- what is proper restart procedure for car parked for more than 6 months?
- Should I Stay or Should I Go???
- follow the owners manual for spark plug replacement?
- 98 GS300 Random Hiccuping
- Code to program SC430 to unlock passenger door
- MAX Cold is COLD; Everything Else HOT!!
- Compressor
- '93 LS400 Spark plug change
- Guide to Replace Drive Belt & Tensioner 97' SC300????
- Recommendation for trunk lift supports part
- 160,000 mile service
- DIY brake fluid flush
- Lexus dealer alignment cost
- Lexus Roadside Maintance vs. AAA
- Is this a fair Price to Change Condensor?
- tranny slipping?
- Forgot to put the oil plug gasket back on
- Replacing Alternater and Starter on LS400?
- 87 gas
- Suggested Tranny Fluid for a 93 GS300??
- Corded impact or cordless impact wrench?
- Lexus Technician as a career?
- manual transmission flush
- CEL Code
- how can i keep my baby..... 270,000+ miles
- 95 SC400 AC Charge
- Cracked Winshield =(
- SC400 Shock Replacement
- 90k Service Parts list for 2001 GS300
- Vehicle Platinum Care
- Sales at Advance Auto
- Mobil 1 on sale at Costco
- sc300 oil change
- Bad Es300 engine
- Need some Techs with expertise gs300
- 92 sc400 oil change. need help!!
- repair manual ?
- Tranny Filter change... Worth it?
- Where did my oil go?
- Anyone mailed Lexus corporate?
- engine idle problems
- Dealer estimates on things you can do yourself
- VSC, Brake Light, abs lights - all on
- Vsc Trac Off Cel
