Does anyone use K&N air filters?
Old Sep 4, 2008 | 06:00 PM
lexusman08's Avatar
lexusman08
Default Does anyone use K&N air filters?
In my old Accord, a K&N air filter seemed to improve engine sound and performance a bit. I also appreciated the extended period before I had to change them. Do any of you use K&N filters in your Lexus engines?
Thanks
Old Sep 4, 2008 | 06:21 PM
Spitfire86's Avatar
Spitfire86
Use the search function, this has been talked about a lot! Some use it some don't. Watch out for when you clean it b/c the oil may mess up the MAF.
Old Sep 4, 2008 | 08:04 PM
steviej's Avatar
steviej
I used one in my 2002 ES for about three years. The mpg improvement was negligible. The only savings was not having to buy a stock filter each year.
The hassle is having to wash, re-oil and make sure you don't over oil the K&N each time. I went back to the simplicity of the Denso filters just to avoid the re-oiling.
steviej
Old Sep 4, 2008 | 08:26 PM
Lexmex's Avatar
Lexmex
With my RX300, a long time ago (6 years ago) in a galaxy far, far away (Mexico City), I used one and also had the issue with the MAF sensor getting coated. Ended up just spraying the side facing the airflow to avoid this issue. I noticed this filter a bit more than I would at sea level. Compared to the stock filter, I felt that using one for the situation I was down there was the right one, but whether you want to use one is a personal decision.
Old Sep 4, 2008 | 09:50 PM
Trexus's Avatar
Trexus
I got a real good deal on an Airhog Fram filter which is very similar to a K&N filter and I do notice the sound and pick up on my 1996 ES 300. The filter is good for 1,000,000 miles...
Old Sep 5, 2008 | 09:09 AM
4ntvings's Avatar
4ntvings
check your local Lexus model forum in CL
LOL
Old Sep 5, 2008 | 12:29 PM
Kaydee's Avatar
Kaydee
Hacked CL to become a Mod
I used it for 2 days...felt no change whatsoever, read up on how to clean the filter, and decided to put OEM back...too much hassle. Now it's just sitting in garage collecting dust
mitmaks
Feb 26, 2012 06:23 PM
aznking
IS F (2008-2014)
Jul 15, 2010 07:51 AM
Enz
RX - 1st Gen (1999-2003)
May 28, 2010 03:37 PM
guod
Sep 15, 2009 06:57 PM
ravengotu
26
May 4, 2006 06:10 PM
