New to this forum.
Old Aug 19, 2010 | 09:31 AM
LowRX's Avatar
LowRX
Default New to this forum.
So I recently bought my wife a '99 RX 300 and on the drive home noticed the CEL came on with a P0171 lean on bank 1 code. I have already cleaned the MAF and have heard that there are a few other sensors that are notorious on these cars to cause this code. My question for any/all of you is what have you done when getting this code to resolve it to narrow down this issue.
I come from the VW/Audi world where we have Vag-Com to easily diagnose whats wrong, but I cant seem to find any decent software for these cars. Thanks guys.
Old Aug 19, 2010 | 04:10 PM
LowRX's Avatar
LowRX
Wow this place moves fast. :P
Old Aug 19, 2010 | 04:22 PM
hypervish's Avatar
hypervish
Not everybody knows the answer to every question thats asked, but we try our best. Patience is the main ingredient in solving a problem!
I would start by cleaning the throttle body, and the IACV and go easy on the screws because they are extremely soft.
DIY: https://www.clublexus.com/forums/rx-...-write-up.html
Old Aug 25, 2010 | 04:29 PM
LowRX's Avatar
LowRX
So the sensor and TB were dirty, but that didnt fix it. ANy other ideas.
Old Aug 25, 2010 | 04:58 PM
hypervish's Avatar
hypervish
Run some fuel injector cleaner through it, it may be a injector blockage or low pressure. Is the exhaust leaking anywhere making the A/F ratio go "crazy". If you changed the air filter recently, there a few air intake lines on the box in which the air filter is located, you may want to check those. If your still running lean, check the spark plugs, check the o2 sensor's, and check the a/f sensor.
If this is too much, head on over to your local trusty mechanic, seeing as though you come from Audi and VW this can't be anything compared to that...lol
Old Aug 25, 2010 | 07:28 PM
thomas1's Avatar
thomas1
You might look at this posting
https://www.clublexus.com/forums/rx-...172-p0175.html
Old Aug 26, 2010 | 03:41 PM
LowRX's Avatar
LowRX
Lol, no its not too much, I will check it out... It would be nice to have diagnosing software that wasn't so vague.
Old Aug 26, 2010 | 04:38 PM
iolmaster's Avatar
iolmaster
This is just one possibility. I had the exact code on my 2000 and changed the MAF sensor and that was three months ago and the light has not come back on. The Toyota dealer said this is a common sensor to go in that time frame. It is very easy to do and I recommend replacing rather than cleaning. I tried the cleaning with no effect. As soon as I replaced it the light went away.
Old Aug 26, 2010 | 06:11 PM
hypervish's Avatar
hypervish
Replacing the MAF sensor may solve the light, and it may not. It's better to check everything, before throwing parts at the car.
Old Aug 27, 2010 | 08:07 AM
LowRX's Avatar
LowRX
Agreed. Already tested the MAF as well and it functions correctly. Thanks for the input though.
Tofubento
Apr 15, 2018 05:23 PM
NoShowNoGo
Jul 23, 2015 06:23 AM
bigrobbyt
Feb 26, 2013 08:19 PM
sluggo42
Dec 19, 2012 02:23 PM
richonline
Nov 11, 2010 05:11 PM
