Wheel/rim issue
Old Dec 29, 2015 | 01:17 PM
RX3302004's Avatar
RX3302004
Default Wheel/rim issue
I have an 04 RX, original wheels, 81k miles. I had our tire dealer (who is awesome) install a set of Michelins a year ago. Recently the right front has been losing air. Took the truck in for a rotate and balance at the same installer, they couldn't find anything wrong with the tire. Now the tire is the right rear. Same issue, they looked at it today and said the wheel has corrosion which is causing the tire to slowly lose air. They sanded it down but said I may need a new wheel at some point.
Is this common? Any suggestions? Thanks.
Old Dec 29, 2015 | 08:17 PM
NVAKeith's Avatar
NVAKeith
I've had a similar consistent leak with a new tire that was traced to a defective valve stem.
A colleague had a corrosion issue along the bead on his Altima's alloy wheels that affected two or three wheels. I haven't heard of it on a Lexus.
Old Dec 30, 2015 | 08:49 AM
dganapol's Avatar
dganapol
Hi,
I had the bead problem, I had to get is resurfaced at tire rim shop, corrosion.
David
firegoose
Wheels, Tires & Brakes Forum
15
May 9, 2012 06:49 AM
SGT
Apr 28, 2006 08:23 AM
lic2q
Jul 18, 2005 10:06 PM
jamecl
Oct 13, 2002 05:53 PM
D-MAN63
Nov 14, 2001 04:22 PM
