yellow light indicator is on after replacing combustion engine
Dear members. I ll like to share with you my experience with an RX 400H 2006 model. After 130k km of a European model issued in Greece, the car suddenly stopped with check hybrid warnings. The one and only lexus dealer in Greece replaced the hybrid unit due to failure of the power module. ( the car was on recall but they have never contacted me). After the replacement there was a rattle sound coming from the combustion engine when it was running on the morning for 3-5 min.The new inspection of the dealer showed a crack on the head gasket of the 4th cylinder.( I have post it here under a different username) . The options that I was given was either to have the engine replaced with a used one or to fix the old engine. The cost of fixing was triple of finding an engine. So I purchased a used one (via ebay!) , it was from a car issued in the United Sates. The one and only dealer refused to put it on my vechicle because it wasnot going to fit and work due to different electrical wiring . So I found a mechanic who managed to put on the us engine easily and with no issues except from a yellow light that goes on seconds after staring the ingnition key.On the diagnostic tool shows a warning about ABS system although the barkes are ok and ABS works fine. The car is running after engine replacement for 25k km with no problems. I attach a photo of it . Is may member have any solution to this problem and what will be the cause of this. thanx
