2007 RX350 cold startup rattle
Old Apr 1, 2016 | 03:23 PM
randyvand's Avatar
randyvand
Post 2007 RX350 cold startup rattle
Hello all. Our 2007 RX350 with 91,000 miles started an annoying rattle at startup that lasts a couple seconds then goes away. The car drives fine and makes no unusual noise after the initial start. Any TSBs that anyone knows about or anywhere I can start looking. Its definitely not normal as it hasn't done it the last 91K miles we have driven the car. Thank you!
Old Apr 1, 2016 | 04:17 PM
aachowhan's Avatar
aachowhan
Could be your timing chain. Get your timing checked out, that indicate if you need a new chain.
Old Apr 2, 2016 | 08:16 AM
NVAKeith's Avatar
NVAKeith
Check the water pump too.
https://www.clublexus.com/forums/rx-...inal-went.html
Old Apr 4, 2016 | 07:04 PM
sightdev's Avatar
sightdev
use OEM oil filter and your problem solved.
nikolai00
Oct 2, 2018 07:19 PM
Ssd108
Hybrid Technology
13
Jan 15, 2018 12:28 PM
SilverES06
12
Dec 19, 2015 10:03 AM
SGS3
Aug 29, 2012 03:58 PM
nyardich
May 22, 2011 12:51 AM
