Help: bumper cost and touch screen problem
Old Nov 21, 2019 | 12:19 PM
AdemolaAd's Avatar
AdemolaAd
Default Help: bumper cost and touch screen problem
hello
does anyone know how much back bumper cost for is 350 2007 cost as well as the back sonar parking sensors ..also my touchscreen is not responding to touch..does anyone know how to reset the navigation system
Old Nov 22, 2019 | 08:35 AM
kevin3344's Avatar
kevin3344
Probably a few hundred dollars for the bumper and sensors. Do a search on eBay (and be sure and vet the sellers). As far as the touch screen goes it sounds like you might need a digitizer. Do a search on ClubLexus there is a thread on how to replace it.
Old Nov 24, 2019 | 09:17 AM
whitebeast's Avatar
whitebeast
Resetting navigation won't fixed touchscreen problem.
Old Nov 25, 2019 | 09:20 AM
oscar0742's Avatar
oscar0742
Originally Posted by AdemolaAd
hello
While I don't know the exact cost of replacement for the bumper I can definitely help with the non responsive touch screen. I had this happen to me not too long ago and the fix is pretty simple and cheap, compared to the approximate $2000 that Lexus will charge you. Typically on our cars the digitizer seems to go out for whatever reason and it means you will no longer be able to use any of your ac or radio functions on screen. Check this link out on how to take apart your dash and how to change your digitizer, all you need is a 10mm socket and a pair of screwdrivers.
Old Nov 26, 2019 | 05:59 PM
AdemolaAd's Avatar
AdemolaAd
i can't see any link...thanks in advance
Old Nov 26, 2019 | 08:58 PM
oscar0742's Avatar
oscar0742
https://www.clublexus.com/forums/is-...n-fix-diy.html
Oops, I must've forgot to paste the link. Also this is the digitizer I bought and used to fix my screen, worked perfectly and I dont have any issues at all with it.
https://www.ebay.com/itm/NEW-Lexus-G...53.m2749.l2649
jwlam
NX - 1st Gen (2015-2021)
16
Apr 19, 2019 06:32 AM
DaveK1NYK
Jan 3, 2016 07:38 AM
jdm_altzza
IS F (2008-2014)
35
Nov 14, 2013 09:37 AM
5150evh
May 7, 2011 06:46 AM
Jooleee
Dec 15, 2003 09:51 PM
