Replacing bank 1 sensor 2 02 sensor?
Old Nov 15, 2019 | 11:26 PM
ivanb7s's Avatar
ivanb7s
Default Replacing bank 1 sensor 2 02 sensor?
Hey guys i read somewhere but i can't find the thread of replacing the dowbstream 02 sensor. I have a new one to put in on sunday i know where the sensor is located. But i have read you need to to just pull the drivers side carpet to get to the connector others said you need to remove the whole drivers seat to get to it. I want to do this the easiest possible. Can someone confirm for me? Btw is bank 1 sensor 2 after the cat.
Old Nov 16, 2019 | 12:02 AM
IS250DIYER's Avatar
IS250DIYER
Yes you can pull the carpet back. I have done this to both sides. B1S2 and B2S2 are after the cats right under the floor where your feet would rest. I dont have pictures but if u dont mind yanking at the carper a bit it should go back in place. start from the front and make your way back till you are under the radio or a bit past. Only needing to pull enough to get to the plug for the 02 sensor.
Tips:
* go to your local auto store and get an O2 sensor socket
* use penetrating oil like BP blaster where the O2 sensor screws in to the exhaust. Make sure to clean it up before installing the new one.
* warm your car up to operating temperature then loosen the O2 sensor after you shut the car OFF. be careful the exhaust is extremely hot.
* do a good arm workout a night before replacing the o2 sensors.
If u have any other ?'s il be happy to help any way i can.
Aathon h.
Old Nov 16, 2019 | 07:42 PM
primavera's Avatar
primavera
https://www.clublexus.com/forums/is-...l#post10462441
Old Nov 18, 2019 | 07:14 AM
2013FSport's Avatar
2013FSport
If you still have an error code for B1S2 it is likely because bank one is on the right side of the vehicle.
FWIW: Reference is always from the drivers seat looking forward.
B1S1 = right front
B2S1 = left front
B1S2 = right rear
B2S2 = left rear
Old Nov 29, 2019 | 07:56 AM
ivanb7s's Avatar
ivanb7s
Tips:
Aathon h.
Great thank you so much i will try to attemp this in a few days.
Old Nov 29, 2019 | 08:02 AM
ivanb7s's Avatar
ivanb7s
thanka brotha for the link.
Lexmex
RX - 1st Gen (1999-2003)
184
Sep 18, 2025 02:50 PM
Sanpete
14
Dec 18, 2014 02:07 PM
ADENNARD
May 21, 2013 06:27 AM
bcg02
Mar 4, 2012 12:34 AM
ynvme
May 28, 2006 08:01 PM
