- Power steering?
- 1jzgtte or 2jzgtte
- Thanks to Phil
- anyone????? ( crankshaft pully is left or right hand thread ?)
- Alternator question
- Interesting response from xerd dealer
- What the HELL are these fleabay auctions about?!
- 8920 tach adapter
- Rebuilt starter on '93 SC300???
- A few transmission problems
- 1UZ-FE to 2JZ-GTTE
- Nos
- Greddy Emanage Ultimate Wire Diagram
- 1JZ TRD Turbo Upgrade?
- Heres a new problem
- NX wet nitrous kit install TPS wire
- What are my options for a 98 SC300 AT without internal mod?
- performance enhancing chips
- help! everything electrical is dead (1jz swap)
- Thermostat question...
- Alternator/Steering pump issue/s
- Stock turbos on 1jzgte
- Exhaust Manifold Gasket
- Question about the Oil Light
- better MPG sc300 or sc400?
- Coming Soon?
- Skyrocketing price of xerd headers.
- 6 blown clutches in 6 months!!!!! help me god
- SC4 Tranny questions
- twin K26 v's GT35?
- mohdparts egr removal kit.
- 2jz-ge engine..........
- 1jzgte with 2jzgte intake?
- Universal Oval Style Canister mufflers
- Anyone ever heard of XSS mufflers?
- 1jzgte
- Airbox cover?
- difference in stock LSD's
- Which stock LSD to get?
- Inno Moto Turbo kit.
- Please help! Power door keep turning on
- TRD LSD SC300 noise & other stuff
- A 97+ US spec 2jz in to a 92-94 body?
- Exhaust + intake mods for 1999 SC400 **HELP**
- What mod should I do?
- AEM standalone with 1JZ
- New SC300 owner - psp pump seal ?
- Shifter Thread Pitch
- clutch recomendations ?
- stock 1jz pipes
- 7m and 1/2j
- lexus sc400 headlights
- Anyone tried/know about the new SSautochrome parts?
- Video of my RMM exhaust on SC400
- AEM/Haltech and others Tuning Session with Justin Nenni in so cal
- 5 speed swap info???
- Drifting
- Please HELP!! 1998-up SC400 Power Steering Pump Question
- One Messed Up Day (Plz Help)
- Rebuilding the 1UZ-FE to 5.0L
- Battery symbol light
- Hey Everyone
- Cheap turbo setup...so i was thinking.
- Exhaust shops?
- nothing to do with SC's, but nice still...
- Darn timing belt looks worn
- VersaTrans ATF?
- intake....
- A little help with exhaust
- Cat is toast...
- help with cold start
- Chirping sound. Pulley question
- I've got lots of issues with my 1JZ I can't solve - ECU, fuel, a/f, etc
- Super Charging Sc400!!!!!
- How well do stock mufflers flow?
- SC300 / SC400 Radiator
- How do I make the 92~97 SC model's Shift to the 99~00 style.
- ? will tt supra cat. conv. fit on sc300??
- Anyone know where to buy resonators?
- A/C died?
- Help! Suddenly have no power (miss?) and smoke from under back of SC400 engine!
- New Dyno numbers for the SC300!
- VPC Dip Switches Ques.
- intake on 98?
- KOYO radiator?
- wiring diagrams
- electrical nightmare
- soarer 2.5 tt auto on sc400?
- stupid problem? VOLTAGE WOES
- How many miles on your alternator?
- Quick questions b4 I buy a 1jz
- knocking
- fuel pump woes
- Power Steering Pump Brand
- My SC is Buggin' me ....Hard!!
- What part is this???
- Problem with throttle body
- got my RMM exhaust! *PICS*
- Engine Miss, come and go 1992 SC300
- SC300 w/manual????!!!!!
- Timing belt advice
- Vehicle Speed Sensor
- I think I need a new oil pan
- Distributor Cap Removal?
- ATTN: Boosted SCs. Firewall and running wires through.
- Finally got my exhaust installed.
- Looks like we may have lost another SC400...
- Finally secured my turbo Lexus...
- OK...so changin the alternator on SC300
- All you AEM Guys
- Shifting into Drive (quick question)
- OBDI tuning questions
- which tach adaptor to use??
- Some pics from my swap.
- RANT ..... No more customer service :(
- heather servo
- New Exhaust Single Exit **pics**
- nice exhaust on ebay
- So how do you know if your A/C Compressor took a crap??
- Just bought a SC300 to na-t or not?
- underpowered?
- vacuum line to boost gauge in glove box
- Help! Help! turbo does not fit. pics
- JIC exhaust
- Torque Converter Upgrade
- 1JZ Spooling Problem
- Distributor O-ring Replacement Write Up
- cobbled together exhaust
- street dynamics NA-T
- Question for the SC400 Owners. Car only running on 4 cylinders
- How do I remove the fan pulley?
- Anyone buy the r154 soarer tranny new?
- engine cuts off?
- Distributor
- Too much gas pressure
- Mechanical line pressure control
- 1J pricing and questions
- TRD Oil Filter Worth It?
- Best year of SC to buy for 2JZ-GTE swap
- Timing question..
- MSD an SAF-2
- 5sp to 6sp swap questions
- Resonators or no?
- SC3 5spd to 6 spd swap
- transmission question
- Special Treat *turbo Hayabusa*
- High Flow Cats in Cali
- na-t manifolds
- Will it work?
- turbo sc400 project started!
- same catalytic converters?? sc300/sc400
- JIC Bullet mufflers
- same mufflers? sc300/sc400?
- Suddenly Stalled, Help...Anyone!!!!??
- Traditional K&N Cone or BFI with K&N Filter
- DIY: How to Install an AEM 1101 EMS into OBD-1 SC300
- Spare airbox for BFI
- Information on 2jz swap?
- supra sidemount ic's
- slow acceleration on my sc400 any ideas?
- Oem Gaskets
- Inno-Moto NA-T Kits
- 1JZ swap list
- WARNING LIGHT on top of the temp gauge (by the H that looks like a gazzibo)
- Quick ques on 1jz tranny/bellhousing for SC300
- ANYONE with 14829's on SC3?
- car running insainly rich, no idea?
- small broken hose underneath car?
- 1jzgte single turbo manifold
- Tips for valve cover gasket?
- what shifter is that?
- Shifting Problem!
- can someone help?
- Magnaflow 14851 - Vid
- Where can I buy a crankshaft pulley?
- Traction off, check engine, and TRAC lights were ON, HELP PLS
- Since everyone is doing a sneak peak...
- Hello from Australia! Question on basic mods for sc300
- na-t page good info
- Little video of my car
- GS400's 1UZ vs SC400's 1UZ
- All error codes listed!
- SC300 Window Wiring??
- FUNNY problems after NA-T
- camshafts
- Where to get a CHEAP MAF sensor
- Looking for help, I/E suggestions
- 2JZ-GTE harness wiring time
- Engine Idle RPM's?
- Smoooking sc300
- 2jz-gte Auto fit in Sc400
- J&S Safeguard --> detonation proof?!
- automatic transmission
- Radiators?
- Highest miles on a NA-T
- NA-T only
- Torque Master spark plugs
- '97 SC300 - messed up bearing
- 1jz serpentine belt
- 1jz overheats?
- 5 or 6 Speed??
- Buying an SC for a project, Qs
- modding sc400's
- anyone got an under the car pic of a single exhaust set up?
- Exhuast Symphony (Story, Pics, and Vids....Oh My!!!)
- Slight ticking...
- Interference or not?!?
- slight rattle when in neutral
- o/d off light blinks constantly
- Magnaflow Race Series Installed
- look what i found on fleabay.....
- NA-T Nearing Completion
- Rod Millen exhaust system!
- sc300 reliability with a turbo?
- 2JZGTE Supra Turbo short block
- Check Engine Light, TRAC light both on AND overheating
- Quick question on Greddy MX!!!!!
- dual exhaust question
- intercooler piping from turbohoses.com?
- pcv valve hose
- car troubles
- Pictures of smic intercooler setup?
- Anyone have the Bible?
- front mount intercooler question
- Exhaust Question?
- sc300 and supra question
- Engine Misfiring
- Baddest SC400
- Where is the best place to by exhaust?
- Extra Heat with A/C
- 5-speed conversion
- 3-way LSD ?
- What electronic/item do you use to correct the speedo if you use an auto TT diff?
- Ordering exhaust! where do I order from?
- engine code 25?
- Need quick answer about serpentine belt.
- Exhaust poll! not 100% sure which one to get!
- Stumbling, bit of hesitation... help
- Anyone know anything about Injen intake?
- sc300/400 rear pumkins compatiable???
- New Memmber See My Ride (Pics)
- Newbie here with the turbo thing
- Anyone with a map ecu on their na-t?
- SC400's Cold Air, Ignition, and Exhaust
- supra clip or soarer
- 1JZ monsters
- Engine hesitation and rear speakers not working
- Anybody actually buying a header from Jbrady?
- Replace valve cover durin tune-up too?
- got my new motor yesterday!
