- Lights needed !!!
- P0125... I need help... A.S.A.P.
- Amsoil Changeover - How?
- ABS Issue Update
- New tire size Yokohama TRZ 225-70-16 available
- 1999 Rx 300 tail lights
- 1999 Rx 300 owners manuel
- Thoughts:Looking at 19x8.5 & 19x9.5 w/245/50/19 & 265/45/19
- Bye Bye Acura TL!!!!! Hello '99 RX-300
- resetting cruise control
- Some Problems
- Need help turning display into a navi system
- IAT Sensor Test
- AC Condenser replacement
- RX300 vs Toyota Celica & Porsche Boxster
- RX 300 Power Door Locks problem
- O2 sensor bad after 90K maintenance
- P1130 and P1135
- Hydrogen Generators
- P1135 air/fuel sensor - VSC Trac light on
- noise from the dashboard - GloveBox
- Driving through high water, wet sensors?
- Dashboard panel lighting?
- Transmission slip between 2nd -3rd
- Ignition coil failure
- need advice - replacing a shock absorber's rubber dust boot
- New member with 03 RX
- Any online parts search pages with diagrams ?
- Oil Type
- brake vibration
- P0171 error code
- Gone 2 weeks Lex batt is dead
- Keep burning out lic plate light
- Any Reviews: Die Hard Platinum P-1 Battery & Hyper Voltage System Gt
- transmission failure 2000 rx300
- What exactly should I ask for during an oil change? + really stupid questions
- Purple Ice
- switchblade key conversion
- Finally got some time
- Factory Hubs
- Problem with Electric Window
- Did anyone ever put......
- Key Help Please-2001 RX 300
- Drive Shaft Flange Bolts
- Lucas Product?
- Fuel economy much improved after tune up
- Toyota says I don't need a timing belt change?
- Cruise control troubleshooting
- dashboard panel lighting question?
- turning throttle cable nuts (for better response)does that change your shift points?
- Lower MPG after timing belt replacement
- Speed Sensor Help
- Unknown Rattle
- Are These Correct For Maintenence?
- Trans pan feels hot
- What voltage should a car battery be at?
- Any Direct Aux-In Solutions yet?
- 1999 RX 300 having trouble starting up.
- pre-sets
- Gas prices.....
- Will 18x8 offset 30 center bore of 66.2 fit a 99 RX
- alignment?
- Original CEL Combo, P0330 P0125 P1155
- Changed all fluids - power steering fluid?
- Upgrading To Sw Intake In Nyc Legeal ?
- Squeaky sun visors
- Chime keeps dinging
- spare tire
- Kool winshield decal with logo what you think?
- Warm air entering cabin
- Passenger Window Gremlin?
- Diy Power Steering Flush??
- Would you be mad and dissapointed?! see pics!
- Dead Battery vs. Throttle issue?
- Overdrive not kicking in?
- Tint for the glass in front of front doors
- Headlight Covers
- Fuel Pump Change
- Vibration on floor along with growling noise
- No AC cooling
- Harsh vibration at high revs (> 4500 rpm)
- DIY IACV clean picture write-up
- Shiny Mirror effect sliver metallic looking Lexus Self Adhesive Acrylic 3 D Sticker..
- 01 RX300 won't start, but starter seems working
- are these oem sparkplugs?
- Bluetooth Car Kit For 2000 Rx 300 ?
- Lubricant for antenna/sunroof
- A/T temp.light
- '01 RX 300 Struts
- Whining noise
- 2000 RX300 tranny went dead
- LCD, Radio, Dome Light, Garage DO OUT
- 02 sensor? has anyone changed it out?
- check engine light help??????
- Air/Fuel Sensor, I'm screwed!
- What strips first plug or pan?
- New Brakes-VSC light?
- Dashboard removal help
- Custom Sunshade for 2003 RX300?
- Dissapointed Again....
- p0110
- vvti variable valve timing ?
- Rare TRD decal badge with japanese characters... what you think?
- Braille Battery
- General reasons for Steering pulling right
- How would your RX look with new wheels
- Extended warranty
- camry brake pads on rx300?
- what service to do before long trip
- 5.00/Gallon
- transmission maintenance ?
- Horns
- 2002 RX won't idle
- High Brake Light Replacement
- Emergency Brake Issiue HELP!!!!
- Clock re-sets itself every time I start...........
- After market rim question please advise? thanks
- Aftermarket air intake filter system? folks who have one please enter....
- Catalytic Converters
- A/C Took the day off
- Automatic transmission indicator light burned out
- Blinking CEL--OK to drive?
- Amsoil ATF Finally Arrived
- Transmission: Fix it or forget it
- Timing belt
- Inner CV Boot leaking grease....
- Farewell
- Adjusting rear wiper blade
- Brake fluid replacement - help a newbie!!;)
- Is it worth replacing the Thermostat when doing the TBelt?
- Glove box light
- help please fast before i lose my mind
- Upstate SC RX Owner's
- 1999 RX300 Front Dash CD Player
- One problem fixed, one new problem... ABS or axle ?
- Brake Problems Brake Booster ABS Adjugator
- Installing headrest DVD system
- Engine Light, MAF, Plan B?
- Houston rx300/330 meets?
- reflectors
- Adjust headlight hi-beam on 2000 RX
- How to change the engine pushing?
- ah finally one popped up.
- interesting...
- 2001 RX300 Alarm / Door locking
- speed sensors on transmission
- installed rear parking sensor.
- So Exactly Where is the VVT Controller?
- More exhaust fun
- will 18x9.5 wheels fit on a rx300?
- Was the mesh transmssion filter OEM in '02?
- FM Antenna Replacement
- OBD Code P0446 question
- What's this rubber thing near the tailpipe?
- RX300 Steering Colume whine
- Balancing Tires after 75K service
- RX300 buying tips for a newbie?
- RX 300 Pulsating Brake pedal
- would these look nice on rx?
- pcv valve
- automatic headlight adjustment? please advise?
- good prices for tires/brakes? with good quality but bargain prices from competeters?
- Cleaning the nav system's laser lens...
- Clear Coat Restorer?
- Yet another sludge thread...
- My last CEL question
- 2000 RX 300 CEL (update of previous thread)
- Transmission Filter Kit
- fuel filters?
- 75,000 is the begining mark of high mileage? please advise?
- Engine flush? please advise?
- Aux input for Non-Nakamichi systems
- Issues with Short drives
- Need advice... Should I raise my deductable?
- here a picture of my rx300
- Front end problem.
- 2000 RX300 CEL questions
- Lexus Rx300 Full Set Pedals? Look!
- 01-03 Front Headlight Fit 98-00 Model Rx?
- TPS and A/F Error Codes
- power antenna motor
- Lexus RX300 USA Brochure Archive
- Passenger's Side Only A/C Not Working
- No heat drivers side only
- mobil 1 synthetic 15,000 mile service?
- Filtermag? Good Investment?
- Kharma, then Teaser...
- 02 RX 300- where to buy back hatch sun cover
- 02 RX 300- need accessory for key
- RX 300-back passenger door wont open from the inside
- oil problem
- Sputtering Rattle Sound? Please Advise? Thanks!
- Filters Replaced-Cost effective maintenance repairs?
- 99 RX300 Engine Sludge Questions
- Gel vs Carbon?
- Aux Input for 1999 Rx300
- lexuspartsonline.com
- Questions about struts and lowering
- 90K service
- does any one know where to buy thermal exhaust?
- Are These Good To Have? Do They Work?
- what is the D.C.C short fuse in the engine compartment?
- Throttle please advise!?
- "what A Dirty Pcv Valve Looks Like! Pics!
- RX300 skid control way too sensitive
- Error code P0330 - Knock sensor replacement
- Help out the new guy!
- A/f Sensors And 02 Sensor Question? Please Advise Thanks!
- Torque Wrench Recommendation
- Quick acceleration vibration
- P0302 - Bad Coil: Thank you Forum & Lexmex
- Where To Buy Front License Plate Holder?
- Fluids for 2001 RX 300
- 2003 rx 300 door lock and shift knob
- Exhaust flex pipe issues
- will 19x8 offset ET20 fit ...Is that too big?
- Should I change my transmission fluid in a high mileage RX?
- Gen 2 Navigation Destination button greyed out
- RX300 - Remote Question
- Screw on add on tips? Anyone do this?
- 2000 RX 300 35,000 mile service
- Something Wrong With Fuse or Wiring?
- cable for mp3/ipod to cd changer connector
- Vibration at speed above 75mph (120kmh)
- Just finished Brake Job- but some problems
- Trans blew on my RX
- Brake job questions
- A big black muffler
- spark plug question oem vs. aftermarket?
- Broken Power Antenna
- Tint
- Odometer Mileage on your RX300
- RX300--Jumping, and Dying, and Stalling (Oh My!)
- Tranny!!
- 2000 Rx300
- Front license plate bracket rx 300 2003
- Using K&N HP-2009 oil filter vs HP-1002
- New owner intro.
- IACV cleanup weekend project
- engine oil and tranny oil , spark plug questions please advise. thanks
- engine oil and tranny oil question please advise. thanks
- Light are Bad
- Any way of checking
- Drive Belts for RX300
- Cel
- REAR HATCH, latches but dash lite & bell indicates “Open” ??
- Should I buy it?
- RX300, Smoking and burning oil at 75k ???
- Rotor Resurface Already?
- Vsc Vehicle Skid Control Light On?
