Kharma, then Teaser...
Old Apr 29, 2008 | 05:01 PM
HarrierRX300's Avatar
HarrierRX300
Default Kharma, then Teaser...
Great... With the gas prices keep going up and up, I tend to take her out not as often as before. The day that I do take her out, on the way home I felt my steering wheel pull toward the right. I got home and looked at the passenger tire. Great... some jealous person stuck a drywall screw in my tire. It's ok. Kharma...(cause and effect) That guy will get his someday.
My question is this. I went to a tire shop and they wanted $30 to patch a tire from the inside. I said nope. I went to a different shop and paid $20 and all they did was jam a rubber sealant into the hole without dismantling the tire. Is this good enough? I got many more miles to go on these tires.
And on with the teaser... I was going to wait until summer to slap these on (I put this on while the flat was being repaired)
Feedbacks welcome..
Old Apr 29, 2008 | 05:02 PM
HarrierRX300
??????? hmmm
Old Apr 29, 2008 | 05:03 PM
HarrierRX300
screw frontal
Old Apr 29, 2008 | 05:04 PM
HarrierRX300
screw side angle
Old Apr 29, 2008 | 05:18 PM
thomas1's Avatar
thomas1
You should be fine, I have used that patch method before (many times) Tire shops will not warrant it however. Your screw was getting close to the sidewall, a little more and the tire would be toast. good luck
Old Apr 29, 2008 | 05:23 PM
salimshah's Avatar
salimshah
25 Year Member
What you got was a plug, instead of a patch. Which is better is debatable. Patch is more effective in the flat area and close to the edge, plug may be better. For sidewall, the patch would not work.
I would limit high speed/aggressive driving with the plugged tire. You can think about the repaired tire as spare.
Salim
Old Apr 29, 2008 | 05:29 PM
Lexmex's Avatar
Lexmex
In Mexico, the patch was always the exclusive way to go, I never saw the worm/gusano, a.k.a. plug. Down there, they charged just under $5 USD. I have had to do the patch a few times and no issues. But in the U.S., you should be equally as fine with either patch or plug.
I would heed Salim's advice on driving high speed/aggressive driving with the tire. Excessive heat can cause issues there.
Old Apr 29, 2008 | 05:51 PM
YoshRX300's Avatar
YoshRX300
I have one also in my tire. Its been plugged like this for about 2 years now with out any issues. I carry one of these self repair kits at all times next to my spare tire.
**Very nice and clean your ride is.
Old Apr 29, 2008 | 07:39 PM
BBLexus's Avatar
BBLexus
unless you plan on driving high speeds or aggressively - meaning a NASCAR style driving - you shouldn't have any trouble. I've had plugs in tires without problems - driving on the tires for years.
Old Apr 29, 2008 | 10:09 PM
salimshah's Avatar
salimshah
25 Year Member
Glad you have had good luck with repaired tires BBlexus. The picture of repair shows the location close to the edge. [the photo can be deceiving]. This area gets flexed on each rotation and the chances of a blowout are higher. As thomas1 pointed out, any further out, the tire shop would refuse to repair for the same reason I stated.
If you have a perfectly good spare, bring that one in service and use the repaired tire as the spare.
Salim
alpha12
Dec 3, 2014 04:14 PM
I8ABMR
Sep 3, 2013 07:45 AM
stech
Wheels, Tires & Brakes Forum
Oct 3, 2007 08:18 AM
PMIRO2
Jun 19, 2007 11:07 AM
zmatrix
14
Nov 11, 2003 04:11 PM
