dashboard panel lighting question?
This is a stupid question but when car is in park (P),reverse(R),nuetral (N), and drive (2) and drive (3) that green light highlights the symbol. The only letter that does not highlight the symbol is the regular (D) drive. Is that on all 99 RX300 or should it be highlighted when in its shifted in the (D)?? Is there a fuse or something for this if its supposed to be lighted when in use? Thanks for the help.
Typically the "D" bulb blows out. Search and you will find instructions on how to replace the bulb. Some folks just leave it alone, other swap the bulbs. A new one form dealer is less than $10.
Salim
Salim
I left mine alone(Burned out) because I find the light some-what distracting.
I have searched and still I am coming up short on finding instructions on how to replace the D bulb for this problem. If anyone comes across it or finds it please let me know. thanks for your help
You will need to remove the 2 philip head screws on the upper part of black plastic cover around the cluster. Then remove the plastic trim around the ignition key cylinder and another plastic trim on the left side ( the seat memory and remote mirror switch are in this trim) and both of these trims just pop out.
After remove the black plastic cover around the cluster, you will need to remove 3 move philip head screws that hold the cluster. Remove the cluster out of its housing and carefully disconnect 3 connectors.
Then place the cluster face down on a towel to protect the clear cover. You will see the 'D' light from the back side. Just count the indicator light start from the bottom until you get to ' D'. Just use a small flat head screw driver and turn counter clockwise to remove the bulb. If you are not sure it's the right bulb you just removes, just shine the flash light behind it . Good luck.
Hgspine
RX - 1st Gen (1999-2003)
May 25, 2019 01:17 PM
