- 200 RX 300 Leaking rear windshield fluid hose
- headlamp assembly
- 02 RX300 Cannot get out of Park-VSC+ABS on
- Keep the '99 RX300 or get another car?
- 2001 RX 300 0171 and 0174 codes showing
- rx300 rear hatch stuck
- Please help! headlight question...
- Looking for Rear Tail Light Cover
- SC400 brake disc conversion.
- AT Oil Temp light came on
- Towing Tow Wiring Easy And Cheap
- Anti Lock Pulses During Normal Braking
- rear end clunking
- Master Key Programming for 99 RX
- Replacing reflective glass
- How to change console language
- Is there a jumper trick to check CEL codes myself?
- A slight different transmission failure question - please help!
- rx 300 2002 france help
- Trans Fluid Change Question - 99RX
- Mold Pitting on Window Trim
- The bussing or winning noice from the transmission
- help - replacing A/F bank 1 sensor 1
- iPod & Sirius Connections for 2002 RX300
- Any DIY headlight removal?
- CD Player not working
- RX stereo just died...help =/
- High RPM's before shifting
- HID light bulb
- 99 RX300 with only 21,000 miles getting code P0500
- what to look for in 2002 rx
- I see transmission issues but...
- 2002 rx muffler
- How Lexus is screwing me on my Transmision
- Anyone looking to do a Highlander trans in an rx300
- Engine Oil Pan Leak at what mileage?
- Going to give a different oil a try
- Help - understanding code P1130 readout
- 2002 rx300 muffler awd
- Diagnosis scanner port
- 2000 Rx 300, With 85007 Miles -- Error Code P0115 --Help Help
- 2000RX: Clock resets on cold night
- I need help.. need to master key
- Front and Back windshield washer dead?
- HID Conversion Kits...
- Rear Window Washer Nozzle
- P1130 codes
- FREE GromAudio USB Ipod MP3 Adapter for RX300
- Informative website
- Finish (paint?) peeling on RX roof rack tracks...
- Tune up gone haywire?
- slotted rotors??
- Excessive Oil Under Engine
- Cel P0171 & Rear Light Failure Warning Light
- Retail/Wholesale Value of 2001 RX 300?
- Transmission Services, etc.
- i need new caliper for my 01 RX300- PLEASE
- Transmission cooler
- I need a New Engine. Advice needed
- 2001 rx300 front bumper cover
- Almost new battery time again
- Malfunction + VSC error lights staying on while driving...
- Front seat back panel falling off
- new rx300 owner
- Need to replace sensors.
- Anti sway bar
- engine sludge
- Buying a 99 RX..Help
- Might buy a 2002 RX300??
- Wheel with audio controls for rx300
- 2001 Rx300 Rotors and shocks
- RX300 knock sensor replacement DIY
- Insane Supercharged RXs from Russia
- Window Switch Problems Pass side
- Need help gathering information on transmission failures
- auto trans fluid flow diagram?
- New Master Remote Key
- Selling my 2000 RX
- passenger seatbelt
- Need advice - 2000 RX300 steering wheel
- Pennzoil Ultra
- Door open sensor and dome light
- how do you guys remove these bolt?
- How much ATF fluid is replaced with rear main job
- List what you've done to prevent transmission failure
- Timing Belt Kit On Ebay.....
- New lights
- Is it mostly the sensor that goes bad on CEL?
- engine knock
- Dealer Code
- interior leather color code.????
- 99 Rx300 navi
- Changing day time running light bulb
- fuse box question
- 02 Sensors /CEL
- front windshield washers
- So I just bought a used RX...
- 2001 lexus RX300 LED signal mirror covers
- My rear wiperarm mod
- Help with hood latch
- Engine and Hood question
- Interesting how long this RX300 survived
- Factory crossbar weight limits
- trans fluid?
- 2002 rx driver door actuator
- Anyone have Yokohama AVID TRZ on their RX300
- CEL P0171 & P1130 - Need Help
- Battery Problem ? rapid ticking noise
- What bulbs do u have in your clear side markers?
- Need Quiet Tires !! (2001 RX-300)
- Oil and filter change, some questions
- Nav button icons
- 2001 Rx300 LED tail light
- Headlight and Bumper
- High Pitched Noise Upon Starting
- Part needed [part number would help too]
- Reinstall rear bumper clip
- Heat / AC Climate Issue
- Water Pump
- rx300 code P0440 what do I check?
- '99 RX front grill paint removal
- V6 3.5L vs V6 3.0L
- What to do with Dead RX300?
- clear side markers
- My RX300 Inspection Failed Because of Battery
- occasional hesitation from a stop
- Who drives with their ABS disabled
- Alignment/Left Pull
- turn signal flasher relay location?
- rough acceleration and jerking transmission
- Rear Main Seal?
- What did you drive before your RX?
- No left turn signal. Help!
- HELP 01 rx300 w HID's dash indicator light question
- Anyone know a Socket Size of the rear axle?
- Need Part
- Broken PCV valve
- No power to Radio/Info center
- AWD question
- help me narrowing down the brake light problem
- need help..new after market hids
- OBD2 scanner versus IT2 scanner
- Victory baby!!!! Just another life lesson. Engine sludge.
- Timing belt for '99 RX at 16,000 miles?
- temperature control not working
- Key/Door Lock Problem
- Security light on solid red
- Our RX got totaled today
- Pic of lowered RX 300 (2000 era)
- tranny cooler
- Check Engine Light comes on usually after refueling
- Help for my rx 300
- VSC and CEl are on.
- Need Help! Trouble Codes: P1354, P0302, P0304, P0306
- Weird alarm/battery problem
- slow acceleration + little shaking from engine in low rpms
- Rust!
- Is ABS working when light is on?
- Garage Door opener
- Pass side window switch problems!
- VSC and Check Engine lights on, but computer says ...
- I can't believe the size of the RX350
- 99 rx300 cel/vsc
- Oil pan leaking - Bolt head sheared off
- Just Turned 210,000 Miles
- RX300 door locks won't work
- Antenna always comes up on any source
- Steering wheel making noise when turning
- My 2002 RX300
- Will this washing machine fit in the cargo area?
- Replacement seat leather source?
- Where to mount ballasts?
- KYB GR-2 with Bad Corrosion Protection
- Timing belt
- Dead Battery, Again.. Battery, Starter, Alternator – Normal
- I now have a p0141 cel code
- Help -Transmission problems due to computer?!
- rx 300 tail light indicator comes on dashboard
- RX 300 Xenon Ballast
- Saw this OBD2 reader on sale
- should i get spacers
- 2000 rx300 / CEL codes
- Debating to either get a Lexus Battery or a Toyota Battery
- lexus dealer suggested $1000 repair after free check; should I go?
- RX 300 Engine help!
- Procedure for changing 99 Rx300 rear half shaft?
- Going to do an Auto-RX treatment on my 1999 RX300
- 1st time buyer of First Generation
- RX300 1999: To Flush or Not to Flush?
- RX300 HID Conversion
- Need help picking suspension upgrade part
- Transmission Died!!!! Now what?
- Transmission wont go in any gear
- What's the OVC?
- Windshield washer pump not working?
- replacing RX grille
- RX300 Problem
- RX300 OEM roof rails
- bottom panels painted in Tampa, Fl
- 99 rx300 knock sensor change
- Last Mod...help needed
- how to find exhaust leak.
- Buying used Rims
- 2000 RX300 Headlight Problem
- RX300 or RX330? Your thoughts.
- Door Locks
- Advice on Current extended warranties?
- 99' rx300 wiring diagram anyone?
- 2002 RX300 questions
- 1999 RX300 Hot Catalytic & Exhaust Power loss
- Will the stock 19 inch rx350 rims fit?
- I HATE working on this truck.... valve cover
- Oil drain pan a WEAR item?
- Lock button on Remote
- rx300 p0302 fault code
- Can you please help- Overdrive question
- Transmission Selector Light Replacement
- Engine Transmission Question
- Shifter sticks in park..button wont release to switch gears
- TRAC dash light always ON
- Steering wheel not centering after turning
- Is it over? Transmission whine, slipping, then dead
- Burning rubber smell in Reverse?...
- C/f
- Custom rx300
- Rear Parking Brake Cable Replacement
- error code p1310 ???
- Timing Belt, Water Pump and the 90K Service
- 99 rx300 247,000 and check engine light
- Switch seat cushion????
- winter Hvac question...
- New Owner w/ 30 Day Warranty What to look for??
- "Burned" oil smell....Help!
- Seat Cushion Removal
- Suggest spray color for intake cowl.
- Front Bumper Cover Removal How-to Needed
- Recommendations
- Hello All - Thx 4 this forum
- Loss of clock memory
- error codes p0171 ,p0300,p0301,p0302,p0303
- Long Term Storage Considerations
- 2002 rx300 belt replacement
- Possible Transmission Problem ?
- Heater is not working when temperature is raised above 78 degrees
- Brake light indicator remains on
- Remote Start for this cold winter
- Navigation Help
- Happy new year!!
- 19 inches tire on 2010 RX
- Buzz from engine compartment
